ATC arduino Linuxcnc 2.8
Hi.
I'm trying to build an atc for my mill.
I found this GitHub - mardini1974/ATCduino: Automatic tool changer for Linuxcnc with Arduino UNO
but it has only 8 stations.I will expand later to 20 stations if it works.
I install the atc on linuxcnc 2.8 on debian wheezy and i get only this:
Found ATC (Auto tool changer) and connecting on port
/tty/USB0.................................................................................................
and i waited 15 min and it goes forever.
I think it is missing something.
I did the instalation from the instructions on the github.
Anyone has any idea?
What does
$ dmesg |grep -i "usb"
from the command line say?
Also:
$ lsusb
cnc@cnc:~/linuxcnc/configs/frezz$ dmesg |grep -i "usb"
[ 1.771471] usbcore: registered new interface driver usbfs
[ 1.771531] usbcore: registered new interface driver hub
[ 1.777798] usbcore: registered new device driver usb
[ 1.778889] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.791718] ehci_hcd 0000:00:10.4: new USB bus registered, assigned bus number 1
[ 1.800059] ehci_hcd 0000:00:10.4: USB 2.0 started, EHCI 1.00
[ 1.800150] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.800159] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.800168] usb usb1: Product: EHCI Host Controller
[ 1.800174] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.800181] usb usb1: SerialNumber: 0000:00:10.4
[ 1.800510] hub 1-0:1.0: USB hub found
[ 1.810895] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.811085] uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 2
[ 1.811228] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.811236] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.811244] usb usb2: Product: UHCI Host Controller
[ 1.811250] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.811255] usb usb2: SerialNumber: 0000:00:10.0
[ 1.811563] hub 2-0:1.0: USB hub found
[ 1.811807] uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 3
[ 1.811924] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.811931] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.811939] usb usb3: Product: UHCI Host Controller
[ 1.811945] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.811951] usb usb3: SerialNumber: 0000:00:10.1
[ 1.812258] hub 3-0:1.0: USB hub found
[ 1.812483] uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus number 4
[ 1.812600] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.812609] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.812616] usb usb4: Product: UHCI Host Controller
[ 1.812622] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.812628] usb usb4: SerialNumber: 0000:00:10.2
[ 1.812863] hub 4-0:1.0: USB hub found
[ 1.813100] uhci_hcd 0000:00:10.3: new USB bus registered, assigned bus number 5
[ 1.813194] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.813201] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.813207] usb usb5: Product: UHCI Host Controller
[ 1.813213] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.813219] usb usb5: SerialNumber: 0000:00:10.3
[ 1.813448] hub 5-0:1.0: USB hub found
[ 2.576028] usb 3-1: new full-speed USB device number 2 using uhci_hcd
[ 2.739925] usb 3-1: New USB device found, idVendor=1a86, idProduct=7523
[ 2.739934] usb 3-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.739943] usb 3-1: Product: USB2.0-Serial
[ 2.980026] usb 3-2: new low-speed USB device number 3 using uhci_hcd
[ 3.157924] usb 3-2: New USB device found, idVendor=04f2, idProduct=0833
[ 3.157933] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.157940] usb 3-2: Product: USB Keyboard
[ 3.157946] usb 3-2: Manufacturer: CHICONY
[ 3.182463] input: CHICONY USB Keyboard as /devices/pci0000:00/0000:00:10.1/usb3/3-2/3-2:1.0/input/input0
[ 3.182592] generic-usb 0003:04F2:0833.0001: input,hidraw0: USB HID v1.11 Keyboard [CHICONY USB Keyboard] on usb-0000:00:10.1-2/input0
[ 3.219089] input: CHICONY USB Keyboard as /devices/pci0000:00/0000:00:10.1/usb3/3-2/3-2:1.1/input/input1
[ 3.219314] generic-usb 0003:04F2:0833.0002: input,hiddev0,hidraw1: USB HID v1.11 Device [CHICONY USB Keyboard] on usb-0000:00:10.1-2/input1
[ 3.219637] usbcore: registered new interface driver usbhid
[ 3.219644] usbhid: USB HID core driver
[ 3.400031] usb 4-1: new full-speed USB device number 2 using uhci_hcd
[ 4.492592] usb 4-1: New USB device found, idVendor=16e3, idProduct=f9e9
[ 4.492601] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.492610] usb 4-1: Product: USB Touch Panel
[ 4.492616] usb 4-1: Manufacturer: ITM Inc
[ 4.816038] usb 4-2: new low-speed USB device number 3 using uhci_hcd
[ 4.984599] usb 4-2: New USB device found, idVendor=1bcf, idProduct=0005
[ 4.984608] usb 4-2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 4.984616] usb 4-2: Product: USB Optical Mouse
[ 5.006096] input: USB Optical Mouse as /devices/pci0000:00/0000:00:10.2/usb4/4-2/4-2:1.0/input/input2
[ 5.006257] generic-usb 0003:1BCF:0005.0003: input,hidraw2: USB HID v1.10 Mouse [USB Optical Mouse] on usb-0000:00:10.2-2/input0
[ 10.654740] input: ITM Inc USB Touch Panel as /devices/pci0000:00/0000:00:10.2/usb4/4-1/4-1:1.0/input/input6
[ 10.654963] usbcore: registered new interface driver usbtouchscreen
[ 10.657851] usbcore: registered new interface driver usbserial
[ 10.657892] usbcore: registered new interface driver usbserial_generic
[ 10.657922] USB Serial support registered for generic
[ 10.657956] usbserial: USB Serial Driver core
[ 10.659345] usbcore: registered new interface driver ch341
[ 10.659380] USB Serial support registered for ch341-uart
[ 10.672182] usb 3-1: ch341-uart converter now attached to ttyUSB0
[ 973.320179] usb 3-1: USB disconnect, device number 2
[ 973.320544] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
[ 973.560084] usb 3-1: new full-speed USB device number 4 using uhci_hcd
[ 973.723131] usb 3-1: New USB device found, idVendor=1a86, idProduct=7523
[ 973.723143] usb 3-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 973.723154] usb 3-1: Product: USB2.0-Serial
[ 973.738623] usb 3-1: ch341-uart converter now attached to ttyUSB0
Bus 003 Device 004: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
Bus 003 Device 003: ID 04f2:0833 Chicony Electronics Co., Ltd
Bus 004 Device 002: ID 16e3:f9e9
Bus 004 Device 003: ID 1bcf:0005 Sunplus Innovation Technology Inc.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
i used the arduino serial terminal and it comunicate just fine.
The arduino is closed when i startup the linuxcnc.
Maybe something with the Python serial plugin?
Possibly, but I'm Python ignorant, sorry, good luck.
Ok.thanks for the replay.
