Atlas PH Sensor Query Failed
Hi I have bought Atlas PH Probe and followed the instructions to use the EZO PH circuit in i2c. The board lights up in blue color. When i use i2cdetect -y 1 i am getting default port 0x63 (which is 99 in decimal)in the display. I put the port to 99 in the script even then i am not even able to get any data when i give the command. I used the sample program and followed the mentioned connection from Atlas web page but still I am not getting any value on Arduino serial monitor.
code i used:
//This code will work on an Arduino Uno and Mega
//This code was written to be easy to understand.
//Modify this code as you see fit.
//This code will output data to the Arduino serial monitor.
//Type commands into the Arduino serial monitor to control the Ph circuit.
//This code was written in the Arduino 1.8.9 IDE
//This code was last tested 7/2019
#include <Wire.h>                //enable I2C.
#define address 99               //default I2C ID number for EZO pH Circuit.
char computerdata[20];           //we make a 20 byte character array to hold incoming data from a pc/mac/other.
byte received_from_computer = 0; //we need to know how many characters have been received.
byte serial_event = 0;           //a flag to signal when data has been received from the pc/mac/other.
byte code = 0;                   //used to hold the I2C response code.
char ph_data[20];                //we make a 20 byte character array to hold incoming data from the pH circuit.
byte in_char = 0;                //used as a 1 byte buffer to store inbound bytes from the pH Circuit.
byte i = 0;                      //counter used for ph_data array.
int time_ = 815;                 //used to change the delay needed depending on the command sent to the EZO Class pH Circuit.
float ph_float;                  //float var used to hold the float value of the pH.
void setup()                     //hardware initialization.
  Serial.begin(9600);           //enable serial port.
  Wire.begin();                 //enable I2C port.
void serialEvent() {                                                              //this interrupt will trigger when the data coming from the serial monitor(pc/mac/other) is received.
  received_from_computer = Serial.readBytesUntil(13, computerdata, 20);           //we read the data sent from the serial monitor(pc/mac/other) until we see a <CR>. We also count how many characters have been received.
  computerdata[received_from_computer] = 0;                                       //stop the buffer from transmitting leftovers or garbage.
  serial_event = true;                                                            //set the serial event flag.
void loop() {        //the main loop.
  if (serial_event == true) {                                                     //if a command was sent to the EZO device.
    for (i = 0; i <= received_from_computer; i++) {                               //set all char to lower case, this is just so this exact sample code can recognize the "sleep" command.
      computerdata[i] = tolower(computerdata[i]);                                 //"Sleep" ≠ "sleep"
    i=0;        //reset i, we will need it later
    if (computerdata[0] == 'c' || computerdata[0] == 'r')time_ = 815;             //if a command has been sent to calibrate or take a reading we wait 815ms so that the circuit has time to take the reading.
    else time_ = 250;                                                             //if any other command has been sent we wait only 250ms.
    Wire.beginTransmission(address);                                              //call the circuit by its ID number.
    Wire.write(computerdata);                                                     //transmit the command that was sent through the serial port.
    Wire.endTransmission();                                                       //end the I2C data transmission.
    if (strcmp(computerdata, "sleep") != 0) {  	                                  //if the command that has been sent is NOT the sleep command, wait the correct amount of time and request data.
        //if it is the sleep command, we do nothing. Issuing a sleep command and then requesting data will wake the circuit.
      delay(time_);								                                                //wait the correct amount of time for the circuit to complete its instruction.
      Wire.requestFrom(address, 20, 1); 		                                      //call the circuit and request 20 bytes (this may be more than we need)
      code = Wire.read();               		                                      //the first byte is the response code, we read this separately.
      switch (code) {							          //switch case based on what the response code is.
        case 1:                         		//decimal 1.
          Serial.println("Success");    		//means the command was successful.
          break;                        		//exits the switch case.
        case 2:                         		//decimal 2.
          Serial.println("Failed");     		//means the command has failed.
        case 254:                       		//decimal 254.
          Serial.println("Pending");    		//means the command has not yet been finished calculating.
        case 255:                       		//decimal 255.
          Serial.println("No Data");    		//means there is no further data to send.
      while (Wire.available()) {         		//are there bytes to receive.
        in_char = Wire.read();           		//receive a byte.
        ph_data[i] = in_char;					      //load this byte into our array.
        i += 1;                          		//incur the counter for the array element.
        if (in_char == 0) {              		//if we see that we have been sent a null command.
          i = 0;                         		//reset the counter i to 0.
          break;                         		//exit the while loop.
      Serial.println(ph_data);          		//print the data.
    serial_event = false;                   //reset the serial event flag.
  //Uncomment this section if you want to take the pH value and convert it into floating point number.
  //ph_float=atof(ph_data);
connection I followed:
any help on why there are no readings?
Your picture isn't showing
That's a command for Linux based boards (p.e. Raspberry Pi). Did you wire it to the Raspi or to an Arduino? The document you linked to (it's not an image, it's a PDF document, so it doesn't show up when referring by an image tag), shows the wiring for only Arduino UNO and Mega2560. Post the wiring you did and post details about which board you connect that sensor board to.
Hi pylon,
I wrote it for arduino uno.
here is the connection i used:
https://www.atlas-scientific.com/_files/code/Ardunio-I2C-pH-sample-code.pdf
I sent the PDF file because it is more clear.
BTW the sensor is working well with UART mode while there are no readings at all in I2C mode
this is the pdf link u can see the connection i used.
Do you get no value or no output at all?
What do you send to the Arduino? If you do not send commands to the Arduino from the PC, it does nothing.
No output at all.
actually I'm using a sample code from atlas website which is included with the connection i sent above. It should work as i am giving the correct address.
Above posted code does nothing if you don't send appropriate commands by the serial interface to the Arduino.
What does "giving" mean? How do you "give" that address?
