Hello, I was given two Atlas Scientific PH sensors. They come with to circit boards also made by Atlas Scientific PH sensor. However, these boards do not have any model numbers indicated. They look like in th attached pics. I search on the web saw different kinds of boards but not the ones that I have. So I connected Tx to Arduino pin 2 , Rx to Arduino pin 3 on, GND to Arduino GND. The PWR led lits up on the board, but this is about it. I tried this sketch donwload somewhere
//This code was written to be easy to understand.
//Code efficiency was not considered.
//Modify this code as you see fit.
//This code will output data to the Arduino serial monitor.
//Type commands into the Arduino serial monitor to control the pH circuit.
//This code was written in the Arduino 1.6.5 IDE
//An Arduino UNO was used to test this code.
#include <SoftwareSerial.h> //we have to include the SoftwareSerial library, or else we can't use it.
#define rx 2 //define what pin rx is going to be.
#define tx 3 //define what pin tx is going to be.
SoftwareSerial myserial(rx, tx); //define how the soft serial port is going to work.
String inputstring = ""; //a string to hold incoming data from the PC
String sensorstring = ""; //a string to hold the data from the Atlas Scientific product
boolean input_stringcomplete = false; //have we received all the data from the PC
boolean sensor_stringcomplete = false; //have we received all the data from the Atlas Scientific product
float ph; //used to hold a floating point number that is the pH.
void setup() { //set up the hardware
Serial.begin(9600); //set baud rate for the hardware serial port_0 to 9600
myserial.begin(9600); //set baud rate for software serial port_3 to 9600
inputstring.reserve(10); //set aside some bytes for receiving data from the PC
sensorstring.reserve(30); //set aside some bytes for receiving data from Atlas Scientific product
void serialEvent() { //if the hardware serial port_0 receives a char
char inchar = (char)Serial.read(); //get the char we just received
inputstring += inchar; //add it to the inputString
if (inchar == '\r') {
input_stringcomplete = true; //if the incoming character is a , set the flag
void loop() { //here we go...
if (input_stringcomplete) { //if a string from the PC has been received in its entirety
myserial.print(inputstring); //send that string to the Atlas Scientific product
inputstring = ""; //clear the string
input_stringcomplete = false; //reset the flag used to tell if we have received a completed string from the PC
if (myserial.available() > 0) { //if we see that the Atlas Scientific product has sent a character.
char inchar = (char)myserial.read(); //get the char we just received
sensorstring += inchar;
sensor_stringcomplete = true; //if the incoming character is a , set the flag
if (sensor_stringcomplete) { //if a string from the Atlas Scientific product has been received in its entirety
Serial.println(sensorstring); //send that string to the PC's serial monitor
ph = sensorstring.toFloat(); //convert the string to a floating point number so it can be evaluated by the Arduino
if (ph >= 7.0) { //if the pH is greater than or equal to 7.0
Serial.println("high"); //print "high" this is demonstrating that the Arduino is evaluating the pH as a number and not as a string
if (ph <= 6.999) { //if the pH is less than or equal to 6.999
Serial.println("low"); //print "low" this is demonstrating that the Arduino is evaluating the pH as a number and not as a string
sensorstring = ""; //clear the string:
sensor_stringcomplete = false; //reset the flag used to tell if we have received a completed string from the Atlas Scientific product
I am not even sure if it is the right sketch. It uploaded to the Arduino just find. But it doesn't produce any output in the serial monitor.
Does this sernor require addditional ibrary? How to get it to work? Thanks.
