Atlas Scientific pH stamp with arduino
Hi arduino gurus
I have ITEADUINO V2.1 WITH ATMEGA328 which same as the old Duemilanove. I also have the Atlas Scientific pH stamp. I would like to do a very simple project but since I am a complete noob, I will need help from you guys.
I would like to trigger some Leds and Buzzer when a certain range of pH is reached. I also want to display the pH on LCD
Here’s my question:
1)Do i need to modify the code given by Atlas http://atlas-scientific.com/_files/code/Arduino-sample-code-EZ-COM.pdf ??
2)I got this code from some one. Once i got the pH to float, I can display it on LCD…but the problem is got erros using this code. Here’s the code
// Simple way to get Atlas Scientific serial PH stamp value to LCD or PC
// Author: Eric van Riet - The Netherlands
// ***************ONLY THE PART FOR PH IS LISTED!*****************
// ASSUMED THAT OTHER LIBRARIES FOR LCD ETC ARE IN YOUR OWN CODE!!
// -------------------------Set measurement interval------------------------------
long phReadInterval = 1000;
long previousMillisPH = 0;
int PHState = HIGH;
// ---------------Variable to hold PH value---------------------------------------
float PH_Val;
  Serial.begin(38400);         // Set baudrate for hardware serial port 0 (PC)
  Serial1.begin(38400);        // Set baudrate serial port 1 to 38400 (PH)
  lcd.begin (20,4);            // initialize the lcd
// -------------Get PH value from Atlas Scientific PH serial stamp----------------
void getPHvalue()  {                //get PH every interval (1000 ms)
  unsigned long currentMillisPH = millis();
  if(currentMillisPH - previousMillisPH > phReadInterval) {
    previousMillisPH = currentMillisPH;
    if (PHState == HIGH)  {
        PHState = LOW;
    else  {
        PHState = HIGH;
        Serial1.print("r\r");  // 'R' reads one value, see stamp doc
        while (Serial1.available() > 0) {
                // Serial1.parseFloat looks for the next valid float number
        // in the serial stream. In this case on hardware serial 1
        PH_Val = Serial1.parseFloat();
        // look for the carriage return. That's the end of your sentence:
        if (Serial1.read() == '\r') {
        Serial.println(PH_Val);  // can be used for debug, pc display etc.
  getPHvalue();
    lcd.setCursor(0,1);
    lcd.print("PH value: ");
    lcd.print(PH_Val);
and here’s the error:
EZ_com.ino: In function ‘void setup()’:
EZ_com:22: error: ‘Serial1’ was not declared in this scope
EZ_com:23: error: ‘lcd’ was not declared in this scope
EZ_com:27: error: a function-definition is not allowed here before ‘{’ token
EZ_com:61: error: expected `}’ at end of input
why???
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
"Serial1" is a feature of the Arduino Mega. If you are using an Arduino clone with an ATmega328 you will need to use SoftwareSerial to communicate with a serial device.
yup i got that.
but how do i get the pH values to float??
A large bucket of water.
Please don't cross-post. It wastes time.
sorry bro.....i guess a noob deserve that joke
some answers can be found here - http://arduino.cc/forum/index.php/topic,104096.0.html -
thanks everybody. i managed to complete it. but how do i connect arduino with Labview? or any other medium so i can display in graphical form?
You can send measurements over serial to labview. I assume it is capable of reading values that come in over a serial line. See - http://diydrones.com/profiles/blogs/using-arduino-with-labview -
Please post the final sketch for future reference.
