atmeg328p at low voltage / frequency
If I want to run an atmega328p at lower voltage, say 2.4V, then I need to use a slower clock.
The question is: will dividing the internal clock (with fuse settings) do, or not?
Does the internal clock require a certain voltage to maintain its 8 MHz, regardless of the divisor, and do I consequently need external crystal to run at for example 1 MHz and lower voltage?
|500x263
More details in the datasheet.
