Atmega 1284 Label
I usually place one of these labels on my stand-alone chips as my memory is crap.
I thought others might want to do the same.
This pin out is for Crossroad's Bobiuno definition.
  1. Print the attached PDF on a sheet of 8 1/2" X 11" label in your printer
  2. I use: AVERY 5165/8165
  3. Laminate your full page.
  4. Cut out a label as needed then remove the carrier sheet from the back
  5. Apply to your 1284 controller
  • You can use double sided tape instead of the AVERY label.
Merry Christmas
EDIT: You can use Scotch tape to laminate your sticker.
Atmega 1284 Label.pdf (174 KB)
You can capitalize the M if you wish, or not. Nobody will laugh. :slight_smile:
Sample:
Nice. Thanks.
No eye-catcher for the PWM pins?
@CB
New version put into original post, thanks.
