Hi
What are the major differences between these 2 beside the flash side and ram i?
i have code developed for arduino mini pro with 328 , but i found several 168 versions at very good price..
Will the code run if it fits the flash and ram requirements ?
i need to use i2c and spi will the libraries that run on the 328 run on the 168 ?
Go to www.atmel.com
At the top, hover over 'Products' and on the fly out menu select 'Atmel AVR 8-and 32-bit
On the new page, on the left hand side, select megaAVR (or the tinyAVR if you're working with the Tiny family)
Now on the new page, under where it says 'megaAVR', click on the 'Parameters' tab
Now you can either compare all the ICs on that table (remember to scroll right).
OR, do what I do which is to download the CSV file (link is at the top of the table) and open it up in Excel. When I want to compare several different ICs, I copy their respective rows into a new sheet, then compare them. This is easier than having to scroll up and down if what you're comparing are several rows apart.
