ATmega 2560 programming without bootloader [SOLVED]
I've made standalone Atmega2560(ATmega 2560-16PA, 2*22pF ceramic capacitors, 16MHz crystal resonator,100nF capacitor between GND and VCC) board, but I can't write any arduino code to it. I sucessfully wrote bootloder with my usbasp programmer from ARDUINO IDE(from Win7 x64 and ArchLinux), then I tried upload sketch(Blinky led - ledpin=13, ATmega pin=26) also with USBasp -
int led = 13;
  pinMode(led, OUTPUT);
  digitalWrite(led, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);               // wait for a second
  digitalWrite(led, LOW);    // turn the LED off by making the voltage LOW
NOTHING HAPPENS.
Then I tried programm sketch without bootloader - also nothing happens. (Changed necessary files)
preferences.txt:
upload.using=usbasp
and also boards.txt:
###mega2560.upload.protocol=wiring
###mega2560.upload.maximum_size=258048
###mega2560.upload.speed=115200
mega2560.upload.using=usbasp
NOTHING HAPPENED Then I tried burn bootloader, using avrdude:
$ avrdude -c usbasp -p m2560 -P usb -b 115200 -e -u -U lock:w:0x3F:m -U efuse:w:0xFD:m -U hfuse:w:0xD8:m -U efuse:w:0xFF:m
$ avrdude -c usbasp -p m2560 -P usb -b 115200 -V -U flash:w:stk500boot_v2_mega2560.hex
$ avrdude -c usbasp -p m2560 -P usb -b 115200 -U lock:w:0x0F:m
ALSO NOTHING HAPPENED, then I wrote simple programm in AVR Studio 6, uploaded with my USBasp programmer
#define F_CPU 16000000UL
#include <avr/io.h>
#include <util/delay.h>
int main(void)
	DDRB=0xFF;
	while(1){
		PORTB=0x00;
		_delay_ms(500);
		PORTB=0x80;
		_delay_ms(500);
	return 0;
Uploaded, and LED blinks without any problems. So there is no errors in schematic.
Then I followed these instructions:
FOUND reason, USBASP cannot programm ATmega2560 microcontrollers
