Atmega 328 bootloader or not?
I have what seems like an easy question to answer however, I am tired of looking for the answer, so I will just ask it.
I have an Arduino Uno and want to take the already programmed chip that's on the Uno and place it on another PCB. Never take it off.
The question is:
What chip do I purchase to replace the one that went on the Uno? Do I have to get the AtMega328 with a bootloader or can I purchase the one without it?
ATMega328P-PU. With or without, your call. If without, there are myriad ways to reprogram it. Such as: use the existing chip to program the new chip, put the new chip in your application.
Can you expand on that? I'm still a bit confused.
If I were to get one without the bootloader can I place it on the Uno (without using the other chip) and upload a program to it? Once it's uploaded, can I then remove the chip and solder it to a PCB that is set to recieve the Atmega328 with the 16Mhz crystal and capacitors and have it work?
Get a solderless breadboard, put the new chip on it. Add the 16 MHz, xtal, 22 pf caps, 10K pullup resistor.
Load the optiloader sketch into the Uno: https://github.com/WestfW/
Now connect Uno pins to breadboard uC pins: +5 to +5, Gnd to Gnd, D13 to D13, D12 to D12, D11 to D11, D10 on Uno to Reset on breadboard uC.
Power up the Uno, the sketch will run and put a bootloader on the blank chip, see the video in the link here: http://arduino.cc/forum/index.php/topic,68183.0.html
Put the newly bootloaded part in your Uno and download your sketch into it. Or leave it there for your next project.
In order for a new chip to function on an Arduino board as an Arduino, it WILL need to have a bootloader.
It is a relatively simple task to put the bootloader onto a completely blank chip, especially if you already have an existing Arduino. You set up a relatively simple circuit with the new chip on a breadboard, and use your existing Arduino as a "device programmer" to burn the bootloader.
Isn't that what I described?
@Crossroads: yep. I was clarifying/rewording, rather than correcting. I guess it would have worked better if I had SAID that!
