ATmega 328 on smaller Arduino boards?
Anyone know if the 328 is available as a surface mount and if so if newly manufactured smaller Arduino boards (eg mini, nano) will be fitted with the 328?
/dl
Seeedstudio has plans on a surface mount 328 on regular size board.
Try making your own; that's always fun! :)
/me
I've been trying to get 328s in the TQFP package myself, but no luck :-(
Still only 168s.
If your going SMD why not go for a 644p? Or 1281 (I think that's the part#).
Because the 328 is a standard arduino processor, no library hacking required for software compatibility?
the arduino mega is a 1280. That 100 pin package is a bit tougher to solder than a 32 or 44 pin TQFP.
-j
it would be cool
ATMEGA328P-AU chips are available, slowly. I have a few dozen now ( http://twitpic.com/39v16 ) but that's after two or three month back-order, and even then my whole order wasn't fulfilled.
I bought a couple of 328 from sparkfun to drop on my Duemilanove. What would proper fuse setting be using
arduino-0013\hardware\bootloaders\atmega168\ATmegaBOOT_168_atmega328.hex
The hfuse and efuse are slightly different between the 168 and 328.
From the make file:
atmega328_isp: HFUSE = DA
atmega328_isp: LFUSE = FF
atmega328_isp: EFUSE = 05
Yes and from boards.txt
atmega328.name=Arduino Duemilanove w/ ATmega328
atmega328.upload.protocol=stk500
atmega328.upload.maximum_size=30720
atmega328.upload.speed=57600
atmega328.bootloader.low_fuses=0xFF
atmega328.bootloader.high_fuses=0xDA
atmega328.bootloader.extended_fuses=0x05
atmega328.bootloader.path=atmega
atmega328.bootloader.file=ATmegaBOOT_168_atmega328.hex
atmega328.bootloader.unlock_bits=0x3F
atmega328.bootloader.lock_bits=0x0F
atmega328.build.mcu=atmega328p
atmega328.build.f_cpu=16000000L
atmega328.build.core=arduino
But this does not seem to work for me. I wonder what I am doing wrong? I can install bootloaders and set fuses on the 168 and all is fine.
Files upload and execute.
I install a bootloader on the 328. I power up the 328 it flashes the led, single flashes. When I try to upload a sketch the tx and rx flash for a moment and then back to the single flash pattern on led. Verbose upload says the familar not in sync.
hmm should I move my questions to newby.help ?
Make sure you change the IDE settings for the 328 -- the bootloader runs the serial port at a faster speed than the 168, so if you don't change the settings, the serial communications to upload your sketch won't work.
Yes I noted the speed as 57600 . I wonder if this speed does not work due to the ‘noisey’ enviroment.
Where would you suggest I post to try and find if anyone has a 328 running on a duemilaove?
Bill
Umm. Its actually standard now. http://tinkerit.myshopify.com/products/arduino
Thanks for the info. I ordered mine last Dec but things change.
In any case my problem turned out to be a bad 328 chip. I tried a differnt one and all works just fine.
Very strange that I could perform HVparellel programming of all features but it would not operate from the UART. Even when I do a full clone of the working chip, and verify it, the bad chip still fails to operate properly.
Sparkfun introduced a 328 Arduino Pro Mini today:
http://www.sparkfun.com/commerce/product_info.php?products_id=9218
Good stuff, maybe the manufacturer(s) of other smaller Arduino borads will follow suit.
Thanks for the link.
/david
I too have been unable to find 328TQFP's in stock anywhere.
You can backorder small quantities of the 328 TQFP @ Mouser. They are listed as "on order" with expected delivery dates of 7/3 and 7/7.
FYI - Mouser is shipping backorders on these now (even though they still don't show current stock).
I placed an order about a month ago and it shipped today.
Cheers!
