Atmega 328 Pin 11 Pin Change interrupt
Hi everyone!
I've been reading over this thread http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1259918394/15 on how to implement a 3rd "software" interrupt,
I am attempting to do the same thing on my Uno using Pin 11 - I have read through the data sheet specifically chapters 11 and 12 and have come up with the following code:
#include <avr/interrupt.h>
#include <avr/io.h>
  pinMode(11, INPUT);
PCICR |= (1 << PCIE1);
PCMSK1 |= (1 << PCINT11);
volatile int print_flag = 0;
ISR(PCINT2_vect)
  print_flag = 3;
ISR(PCINT0_vect)
  print_flag = 1;
ISR(PCINT1_vect)
  print_flag = 2;
  if(print_flag == 1)
    Serial.println("interrupt on pcint 0");
    print_flag = 0;
  else if (print_flag == 2)
    Serial.println("interrupt on pcint 1");
    print_flag = 0;
   else if (print_flag == 3)
     Serial.println("interrupt on pcint 2");
      print_flag = 0;
As far as I can tell from the data sheet this is correct though it doesn't appear to be working,
I tried the Pin 5 example and it works perfectly - any pointers in the right direction would be much appreciated
Thanks,
Dave
I solved my own problem - got mixed up between Pin Numbers and the actual pin mapping :blush:
Here is the correct code:
#include <avr/io.h>
  pinMode(11, INPUT);
PCICR |= (1 << PCIE0);
PCMSK0 |= (1 << PCINT3);
ISR(PCINT2_vect)
  print_flag = 3;
ISR(PCINT0_vect)
  print_flag = 1;
ISR(PCINT1_vect)
  print_flag = 2;
  if(print_flag == 1)
    print_flag = 0;
    print_flag = 0;
      print_flag = 0;
I'm assuming to detach the interrupt I would simple change this:
to this:
PCICR |= (0 << PCIE0);
PCMSK0 |= (0 << PCINT3);
Yes?
Cheers,
Dave
