Hi! We are building a PCB using the atmega328P PU as the main controller, in short, we are trying to make an arduino uno but with less around it...
So we are going to use a wifi chip on the TX and RX pins, programming we did with an arduino uno connected to the MISO MOSI SCK and RESET pins, however we HAVE to be able to also do this with an FTDI chip.
Does anyone know how to use FTDI with MISO MOSI etc. instead of the usual RX and TX?
Oh right, but then you say:
So, how is that less ?
I'm sure I am not the only one confused with what you write.
If you wish to program using SPI, simply use a USBasp device as I do, so simple, it's hardly worth talking about.
You will not be able to use a serial based FTDI with SPI.
The assignment, as you have summarized it, is absolutely ridiculous. Perhaps your understanding of the assignment is not correct.
That said, the FTDI chip does have programmable output lines, and can be used for SPI communications. However, you would have to write your own programming software on the PC/Mac to be able to make use of it that way, and for many reasons, no one in their right mind would do that.
