ATMEGA 328P-PU: Which programmer?
I am looking for a programmer for a couple of ATMEGA 328P-PU.
Often I see that all sorts of microcontrollers are listes - but not the ATMEGA 328P-PU.
Like for example here: www.ebay.de/itm/AVR-51-Programmer-Adapter-mit-10-Pin-Kabel-ATMega-ATTiny-USB-asp-USBISP-Neu-3290-/221669185108
ATtiny12 (L), ATTINY13 (V), ATTiny15 (L), ATtiny24 (V), ATtiny25 (V), ATtiny26 (L),
ATTiny2313 (V), ATtiny44 (V), ATtiny45 (V), ATTiny84 (V), ATtiny85 (V), AT90S2313 (L),
AT90S2323 (L), AT90S2343 (L), AT90S1200 (L), AT90S8515 (L), AT90S8535 (L), ATmega48 (V),
ATMEGA8 (L), ATMEGA88 (V), ATMEGA8515 (L), ATmega8535 (L), ATMEGA16 (L), ATMEGA162 (V),
ATMEGA163 (L), ATMEGA164 (V), ATMEGA165 (V), ATMEGA168 (V), ATmega169 (V), ATMEGA169P (V), ATMEGA32 (L), ATMEGA324 (V), ATMEGA325 (V), ATMEGA3250 (V), ATmega329 (V), ATmega3290 (V), ATMEGA64 (L), ATMEGA640 (V), ATmega644 (V), ATMEGA645 (V), ATMEGA6450 (V), ATMEGA649 (V), ATmega6490 (V), ATMEGA128 (L), ATmega1280 (V), ATmega1281 (V), ATmega2560 (V), ATMega2561 (V), AT90CAN32, AT90CAN64, AT90CAN128, AT90PWM2 (B), AT90PWM3 (B)
Is there something special about the ATMEGA 328P-PU?
ATmega328P is the core of the popular Uno Arduino board and probably the most popular chip in the range for those types of hobby uses (guessing). You should be able to program it using any ISP programmer. If this one can program all of the chips indicated then it is almost certain to cope with an ATmega328P.
However, if you have an Arduino board already you don't need a dedicated programmer. You can use the Arduino ISP sketch from the Arduino IDE and set your chips up on a breadboard. See here: http://www.arduino.cc/en/Tutorial/ArduinoISP (you may also need a 10uf capacitor between Reset on your Arduino and Gnd).
Ugi
If the programmer can do a '168 and '2560 it can certainly do a '328.
I used one of these for a long time
Looks like this could be the same but with a 6-pin header
as I didn't want to deal with the flaky ArduinoISP (at the time - not sure it's any better now from all the questions we see on it) and messing with all the wires every time I wanted to bootload a part.
At some point I managed to hide it on myself, and got an Atmel AVR ISP MKii, and have not had a bootloading issue or an problem with Upload Using Programmer (no bootloader) since with any '328P, 1284P, or 2560 board I've programmed.
They seem to be becoming a rare item tho:
Not in stock from Atmel:
http://store.atmel.com/PartDetail.aspx?q=p:10500054#tc:description
I recently picked up 2 of the last 4 these guys had
https://www.rocelec.com/parts/details/?part=553980c2e4b031f5784cb4f4&build=0
Still 2 left! Not for long I'm sure tho.
Well, I managed to make a mess of those links! Sure difficult to edit a post with links correctly ...
Re: arduinoISP - I just put it on a pro mini, soldered the wires directly onto it and to a 6-pin ISP connector, and then put hotmelt glue over the joints to protect them. That solves the shuffling wires around problem. ArduinoISP seems to work pretty reliably for me, though it's slow.
Glad you have a working solution. My little blue box has performed great for me since Jan 2011, don't plan to stop using it.
I also used if for a while with Atmel Studio - that does some fast bootloading! Only writes the bootload area and not all of the flash.
DrAzzy:
This is what I have in mind: Use one of my China Arduino Nanos (with USB interface) and solder a ISP connector on to it.
When using avrdude, would stk500v1 be the correct parameter for this setup?
E.g. "avrdude -p m328p -P com3 -c stk500v1 -b 19200"
-c arduino
