after i got my screen working on my ESP32Wroom (see topic) I transfered it to my ATmega328P and got the test display working.
Only now I want to put on my own images.
Pinout:
screen 328P
GND -> GND
VCC -> 3V3
SCL -> 13 (D13)
SDA -> 11 (D11)
RST -> A5
DC -> 9 (D9)
CS -> A3
CS-TF ->
OUT ->
On SD card names:
Errors: (none)
Code:
/*This code is meant for the 2.4" TFT LCD touch screen shield with UNO board
* It creates a little slide show of images that changes depending on where you pressed on the screen
* The images are read from SD card
* Refer to SurtrTech.com for more details
#include <SPFD5408_Adafruit_GFX.h> // Core graphics library
#include <SPFD5408_Adafruit_TFTLCD.h> // Hardware-specific library
#include <SPI.h>
#include <SD.h>
#include <SPFD5408_TouchScreen.h> //Touch screen functions library
#if defined(__SAM3X8E__)
#undef __FlashStringHelper::F(string_literal)
#define F(string_literal) string_literal
#endif
//The parameters bellow depends on your shield so make sure the pins are correct
#define YP A3 // must be an analog pin, use "An" notation!
#define XM A2 // must be an analog pin, use "An" notation!
#define YM 9 // can be a digital pin
#define XP 8 // can be a digital pin
//Don't forget if your touch function doesn't work check the values above it may be (A1 A2 7 6) resp
// Calibrate values you may want to run the calibration code first and set those points
#define TS_MINX 176
#define TS_MINY 159
#define TS_MAXX 921
#define TS_MAXY 884
#define MINPRESSURE 10
#define MAXPRESSURE 1000
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
#define LCD_CS A3 // Chip Select goes to Analog 3
#define LCD_CD A2 // Command/Data goes to Analog 2
#define LCD_WR 13 // LCD Write goes to Analog 1
#define LCD_RD 11 // LCD Read goes to Analog 0
#define SD_CS A3 // Set the chip select line to whatever you use
Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, A4);
char x[]="x1.bmp";
/*Here in this code I declared the names as an Array
* So I can do modifications if I want to scroll through
* Make sure you images have a number like "1" so you can increase it or decrease
* to go to the next image
tft.reset();
uint16_t identifier = tft.readID();
pinMode(10, OUTPUT);
digitalWrite(10, HIGH);
tft.begin(identifier);
if (!SD.begin(SD_CS)) {
progmemPrintln(PSTR("failed!"));
return;
tft.setRotation(1); //To do a 90° rotation of the screen
bmpDraw(x, 0, 0); //we draw the first image which is x -> "x1.bmp" as we declared
if(x[1]<49) //So we don't go to some strange values I add here a reset of the values
x[1]=49; //If we're already in the first picture we stay there, same for the last
if(x[1]>52) //"1" in char is "49" and "4" is "52" I wrote them in this format so I can manipulate them
x[1]=52;
TSPoint p = ts.getPoint(); //checking if the user touched the screen
pinMode(XM, OUTPUT);
pinMode(YP, OUTPUT);
if (p.z > MINPRESSURE && p.z < MAXPRESSURE) { //p.z means the pressure value so if the touch wants to be detected
// it pressure should be in this range (it's enough)
p.x = map(p.x, TS_MINX, TS_MAXX, 0, tft.width()); //x and y positions of the touch so the program know the postion where the user has pressed
p.y = map(p.y, TS_MINY, TS_MAXY, 0, tft.height());;
//The screen is rotated like in setRotation(1) so now I'm playing on Y axis only
//And here I got like two big rectangles on the sides of the screen that are considered as buttons
//You can add conditions on x to make small buttons
if(p.y > 0 && p.y < 100 ){
Serial.println("Left"); //I did this to show on serial monitor that I pressed left
x[1]=x[1]-1; //here we change the name of the file we want to read x[]="x1.bmp" and x[1] is the 1 in the name and x[0] is x
bmpDraw(x, 0, 0); //So what I do is just increase it to make it 2 or decrease it to make it 0 (refer to the first "if" to see the solution for this case as 0 doesn't exist)
delay(300); //Then I draw the image which now has a different name depending on which side I pressed
} //Adding a little delay so the touch detection wont bounce
else if(p.y >200 && p.y <320){
Serial.println("Right");
x[1]=x[1]+1;
bmpDraw(x, 0, 0);
delay(300);
#define BUFFPIXEL 20 //Printing speed 20 is meant to be the best, you can go to 60 but using too much RAM
//drawing function no touchy :D
void bmpDraw(char *filename, int x, int y) {
File bmpFile;
int bmpWidth, bmpHeight; // W+H in pixels
uint8_t bmpDepth; // Bit depth (currently must be 24)
uint32_t bmpImageoffset; // Start of image data in file
uint32_t rowSize; // Not always = bmpWidth; may have padding
uint8_t sdbuffer[3*BUFFPIXEL]; // pixel in buffer (R+G+B per pixel)
uint16_t lcdbuffer[BUFFPIXEL]; // pixel out buffer (16-bit per pixel)
uint8_t buffidx = sizeof(sdbuffer); // Current position in sdbuffer
boolean goodBmp = false; // Set to true on valid header parse
boolean flip = true; // BMP is stored bottom-to-top
int w, h, row, col;
uint8_t r, g, b;
uint32_t pos = 0, startTime = millis();
uint8_t lcdidx = 0;
boolean first = true;
if((x >= tft.width()) || (y >= tft.height())) return;
progmemPrint(PSTR("Loading image '"));
Serial.print(filename);
Serial.println('\'');
// Open requested file on SD card
if ((bmpFile = SD.open(filename)) == NULL) {
progmemPrintln(PSTR("File not found"));
return;
// Parse BMP header
if(read16(bmpFile) == 0x4D42) { // BMP signature
progmemPrint(PSTR("File size: ")); Serial.println(read32(bmpFile));
(void)read32(bmpFile); // Read & ignore creator bytes
bmpImageoffset = read32(bmpFile); // Start of image data
progmemPrint(PSTR("Image Offset: ")); Serial.println(bmpImageoffset, DEC);
// Read DIB header
progmemPrint(PSTR("Header size: ")); Serial.println(read32(bmpFile));
bmpWidth = read32(bmpFile);
bmpHeight = read32(bmpFile);
if(read16(bmpFile) == 1) { // # planes -- must be '1'
bmpDepth = read16(bmpFile); // bits per pixel
progmemPrint(PSTR("Bit Depth: ")); Serial.println(bmpDepth);
if((bmpDepth == 24) && (read32(bmpFile) == 0)) { // 0 = uncompressed
goodBmp = true; // Supported BMP format -- proceed!
progmemPrint(PSTR("Image size: "));
Serial.print(bmpWidth);
Serial.print('x');
Serial.println(bmpHeight);
// BMP rows are padded (if needed) to 4-byte boundary
rowSize = (bmpWidth * 3 + 3) & ~3;
// If bmpHeight is negative, image is in top-down order.
// This is not canon but has been observed in the wild.
if(bmpHeight < 0) {
bmpHeight = -bmpHeight;
flip = false;
// Crop area to be loaded
w = bmpWidth;
h = bmpHeight;
if((x+w-1) >= tft.width()) w = tft.width() - x;
if((y+h-1) >= tft.height()) h = tft.height() - y;
// Set TFT address window to clipped image bounds
tft.setAddrWindow(x, y, x+w-1, y+h-1);
for (row=0; row<h; row++) { // For each scanline...
// Seek to start of scan line. It might seem labor-
// intensive to be doing this on every line, but this
// method covers a lot of gritty details like cropping
// and scanline padding. Also, the seek only takes
// place if the file position actually needs to change
// (avoids a lot of cluster math in SD library).
if(flip) // Bitmap is stored bottom-to-top order (normal BMP)
pos = bmpImageoffset + (bmpHeight - 1 - row) * rowSize;
else // Bitmap is stored top-to-bottom
pos = bmpImageoffset + row * rowSize;
if(bmpFile.position() != pos) { // Need seek?
bmpFile.seek(pos);
buffidx = sizeof(sdbuffer); // Force buffer reload
for (col=0; col<w; col++) { // For each column...
// Time to read more pixel data?
if (buffidx >= sizeof(sdbuffer)) { // Indeed
// Push LCD buffer to the display first
if(lcdidx > 0) {
tft.pushColors(lcdbuffer, lcdidx, first);
lcdidx = 0;
first = false;
bmpFile.read(sdbuffer, sizeof(sdbuffer));
buffidx = 0; // Set index to beginning
// Convert pixel from BMP to TFT format
b = sdbuffer[buffidx++];
g = sdbuffer[buffidx++];
r = sdbuffer[buffidx++];
lcdbuffer[lcdidx++] = tft.color565(r,g,b);
} // end pixel
} // end scanline
// Write any remaining data to LCD
if(lcdidx > 0) {
progmemPrint(PSTR("Loaded in "));
Serial.print(millis() - startTime);
Serial.println(" ms");
} // end goodBmp
bmpFile.close();
if(!goodBmp) progmemPrintln(PSTR("BMP format not recognized."));
// These read 16- and 32-bit types from the SD card file.
// BMP data is stored little-endian, Arduino is little-endian too.
// May need to reverse subscript order if porting elsewhere.
uint16_t read16(File f) {
uint16_t result;
((uint8_t *)&result)[0] = f.read(); // LSB
((uint8_t *)&result)[1] = f.read(); // MSB
return result;
uint32_t read32(File f) {
uint32_t result;
((uint8_t *)&result)[2] = f.read();
((uint8_t *)&result)[3] = f.read(); // MSB
return result;
// Copy string from flash to serial port
// Source string MUST be inside a PSTR() declaration!
void progmemPrint(const char *str) {
char c;
while(c = pgm_read_byte(str++)) Serial.print(c);
// Same as above, with trailing newline
void progmemPrintln(const char *str) {
progmemPrint(str);
What is wrong? I also tryed other methods but they were giving errors, with this program I was hoping it worked.
In the end I want it to loop the images on the SD card. With every image beeing freezed for 3 sec.
