atmega 328p works only on arduino board.
Hi.
I have weird problem. I'm testing very simple programs which turns the LED on specific pin. Everything working correctly as long as the atmega is glued to the arduino uno board.
I removed the atmega and placed on breadboard to check the if the same program is running without the board and it is not working.
I checked 4 times, everything is connected properly.
On breadboard I provided power, 5V on pin 7 and grouns on pin 8. What am I missing here?
Crystal.
Reset pulled High (10k?).
Well, I was watching sample projects without crystal.
So the minimum configuration is, VCC, GND and crystal? Where should i pin the crystal?
Now I'm a little bit confused?
So Crystal or Reset with 10k resistance or both?
Btw. Arduino bootloader is already loaded into chip/
I thought we were developing a list for you.
Let's go with both (there may be more!)
But it is pointless. Arduino is a board with make prototyping easier. But I dont want to use board anymore and move solution on breadboard and You want to tell me that, this is nessessary to clone arduino on breadboard. I bet all wee need it's just power.
I'll take a piece of that bet' having built many breadboard 328's. The Uno bootloaded chip has to have the crystal. It needs pull up on reset if you want it to work. And connect 5V and gnd to pins 20 and 22.
And decoupling cap on the power pins.
krzakov:
But it is pointless. Arduino is a board with make prototyping easier. But I don't want to use board anymore and move solution on breadboard and You want to tell me that, this is necessary to clone Arduino on breadboard. I bet all wee need it's just power.
Methinks you need to read this.
Carefully and fully, not assuming that any part is necessarily completely inapplicable to your situation.
