Atmega 329P U-TH vs AU
Hello,
I have a program realized with IDE for a PCB where I'm using the Atmega328P U-TH. This microcontroller doesn't work, but if I run my program and blink program on a Atmega328P-AU yes. Does somebody know what can happen?
-My PCB doesn't have glass
-In both cases, I burn the bootloader and charge using programator with Atmega328 8Mhz internal clock.
I have 100 Atmega328P U-TH and any AU, because this I'm really interested on run with that I have, can be something of fuses?
Thank you,
Roger.
can be.
you say you used programmer to burn the bootloader. was it successful?
if yes, you can copy the fuse setup from AU to U-TH
I'm guessing that this is Google translate for crystal (oscillator) but the OP is probably long gone by now.
