Atmega 644p + hx711 question
I would like to ask about joining together atmega 644p (mighty core) and hx711 module. Did hx711 library will work with that atmega?
The HX711 requires two digital I/O. The atmega644p is quite capable of controlling it.
Why the 644p? If the HX711 is the only hardware being used, an 8k atTiny85 would be sufficient so I suspect there is more to the project than you’re telling us.
It is always best to provide as much information as is possible, not the minimum amount which greatly increases your likelihood of getting a response that may lead you down a path that has a dead end.
