atmega arduino uno
hi guys,
i have a question stay on my level a beginner to arduino. ive raised this before in a other way (project)
ill place my sketch i wanna know why i cant place my 328p in a standby mode in driving a stepper application.
(now in my sketch)
i switch on my power supply for the atmega 328p, current draws 100ma, stays there lovely.
As soon as the chip gets awakened by sensor and the motor starts its job, it draws +- 700ma.
i understand that.
If there is nothing to activate the sensor ie (no motor running) the currnt goes to +- 450ma. This is the state i would like to change after a set time.(the time before i awake the chip as explained before.
i want to basically put my chip in this state.
Pls im using a L293N board, i know its a shit board too late now, i got it.
other problem im having if someone can add on to my sketch my inching of the motor pin 5 i cant seem to get my head around this.
thanks all
[code]
//  Control of a 4 wire stepper motor with optical-sensor (TCST2103) high and low
//  readings with led confirming sensor status, reading 28mm x 32mm label on a roll
//  sensor reading 28mm edge of label. { Motor inch function included (Under Construction.) }
#include <Stepper.h>
//#include <AccelStepper.h>
//#include <MultiStepper.h>
 const int buttonPin = 5;   // pushbutton on pin 3(motor inch)
 const int led = 13;        // led indicator on pin 4
 const int sensor = 2;      // sensor on pin 19
 const int stepsPerRevolution = 200;     // 1.8 degree step motor
 int state = LOW;   // default, no motion detected
 int val = 0;       // variable to store the sensor status (value)
                    // initialize the stepper library on pins 9 through 12:
 Stepper myStepper(stepsPerRevolution, 9, 10, 11, 12);
 int stepCount = 0;     // number of steps the motor has taken
 int buttonState = 0;   // variable for reading the pushbutton status
  pinMode(led, OUTPUT);       // initialize LED as an output
  pinMode(sensor, INPUT);     // initialize sensor as an input
  pinMode(buttonPin, INPUT);  // initialize pushbutton pin as an input:
    val = digitalRead(sensor); // read sensor value
    if (val == LOW)  {         // check if the sensor is HIGH
    digitalWrite(led, LOW);    // turn led off
    buttonState = digitalRead(buttonPin);  // read the state of the pushbutton value:
                              // check if the pushbutton is pressed.
    if (buttonState == HIGH); // the buttonState is HIGH:
   // if (val == HIGH)
   // myStepper.step(10);
    //if (buttonState == LOW);
    digitalWrite(led, HIGH);    // turn led on
    int sensorReading = analogRead(A0);   // pot to adjust motor speed
                                // map it to a range from 10 to 255:
    int motorSpeed = map(sensorReading, 0, 1023, 10, 255);
    if (motorSpeed > 0)
      myStepper.setSpeed(motorSpeed);   // set the motor speed:
                                 // step 1/200 of a revolution:
    myStepper.step(stepsPerRevolution / 200);  // step 1/200 of a revolution:
    //if (val == LOW)
    //myStepper.step(10);
[/code]
Stepper Mptor FL39ST34-0404A.pdf (106 KB)
l298n_dual_motor_controller_module.pdf (1020 KB)
Schematic?
I'm not sure I follow you're description of the problem or what you want it to do, and I have not a clue what you mean by "inching of the motor pin"
hi
by inching the motor i mean jogging (moving) the motor a couple of steps, eg: to feed the label reel in the unit.
ill place the schematics of the sensor unit i made.
what i need is to basically put the chip to sleep after a set time (when not in use) to preserve the motor and driver.
txs all for helping.
You only need one of the Hall effect current sensors. The output of the Hall sensor is connected to an analog pin. Now you can easily monitor what is happening with the servo current.
An Example
Ray
My Projects
