I have set up my ATMEGA328P-PU on a breadboard and am runing off a bench power supply at 5V with just a 16Mhz crystal and a 10K pull up on pin 1 (to prevent reset). I have a precision multimeter wired up in series between the bench power supply and Vcc of my breadboard. After checking the data sheet for the current consumption:
I would expect about 9mA. Agree? However am I reading about 18 mA. In all the power modes, I am finding that I am consuming more current than the graphs show I should. Any idea why this is so?
Look at the first page of chapter 29, those currents are with all peripherals disabled.
All Active- and Idle current consumption measurements are done with all bits in the PRR register
set and thus, the corresponding I/O modules are turned off. Also the Analog Comparator is disabled
during these measurements. The ”ATmega88PA: Supply Current of IO Modules” on page
356 and page 380 shows the additional current consumption compared to ICC Active and ICC Idle
for every I/O module controlled by the Power Reduction Register. See ”Power Reduction Register”
on page 42 for details.
