I was holding a led on top of the atmega chip on the arduino. It fell from my hand on the and the thing which is on the right side of the chip (16.000), and boom the atmega chip caught fire . Now I can't upload any code and when there is power given to the arduino there is a burning smell, please help!
Note:- I don't know how to use forums this is just a simple question
Output in Arduino IDE while uploading code
Sketch uses 444 bytes (1%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x58
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x58
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x58
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xbf
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xef
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x27
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x51
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x65
Failed uploading: uploading error: exit status 1
You are using a breadboard? In that case buy a "classic" Nano instead of replacing the Uno.
If you need to plug a shield into the Uno, then use an Uno.
If you are building a circuit on breadboard, use a Nano or other breadboard-compatible type of Arduino. You might need a larger breadboard because the Nano will take most of the space on a small breadboard, but at least you can build a neat prototype circuit instead of a rat's nest of wires.
Hey @TomGeorge my issue has already been solved. But still thank you for replying.
I have disposed the board, because I don't want it to ruin my home.
Power supply:-PC
