Sorry no, what I mean is how are you wiring them?
What is the connection, are you using USB to rs232 or FTDI interface between the controller and the PC?
I use separate power sources. I think problem is with voltage. When I apply more than 3.3volts(3.5v and above) to the Atmega, the Serial print correctly. but if the voltage is 3.2v or something, it'll start print corrupted string. I don't understand why too, anyhow, i stick to 3.5v or more.
Functions:
Automatic recovery fuse: intelligent anti-burn, equipped with 500mA automatic recovery insurance, automatic disconnection of current over 500mA, protect your device and USB port, even if it is short circuit will not affect, after the circuit is normal, you can restore the link.
CP2102 chip: USB interface chip CP2102, high stability and high performance, communication speed up to 2Mbps. The TTL level is compatible with the 3V3 level standard. It comes with 5V and 3.3V, 4.2V power output ports, which can supply power to the MCU system. The DTR/RTS output interface can be reserved, and the level of the two pins can be overridden through the serial port. When some MCUs download the program, the reset can be completed automatically.
Two-color LED indicator: The indicator light is red and blue respectively to indicate the working status of the module. The TX and RX lamps will flash when there is data transmission, and the transmission status is clearly visible. 3V3/4V2 output selection switch: defaults to output 3.3V from V0 port, short circuit 3V3/4V2, output 4.2V from V0 port, 5V interface directly output 5V.
So the 3V3 might be a bit unreliable.
OR
Have you set the output selection switch?
I connect 3.4v and GND of my external power source to VCC/GND pin of Atmega. RX0/TX0 of Atmega to USB/TTL and connect USB/TTL's GND Pin to Atmega's GND pin.
As I guessed: missing decoupling. Of course given that micro-description is the complete circuit. If not: I repeat, provide complete schematics of your setup!
