This isn't doing what I think the datasheet says it should be doing.. Did I forget some registers or something? Should be no prescaling with 10 bit fast pwm and pin 45 on the arduino mega set to set on bottom and clear on match..
AFAIK timer 5 port b is on pin 45 on the arduino mega.. If I set the ocr5b to 1023 the led lights up a little bit, but not much -- at all other values it's barely visible.
That seems reasonable, had a look at the datasheet - I've not used that exact mode, I've used mode 1010 (phase-correct, programmed by ICR) before (with 16 bit timer1 on ordinary Arduino.
Does sound rather like its still in 16 bit mode rather than 10...
[edit: why not read the various counter control registers back and print them out to double check they have the values you hope? Perhaps one of the #defines is wrong?]
