Atmega165 on Arduino IDE
I've been trying to find out if anyone has used the Atmega165 on the Arduino environment. So far there's been little to no luck.
The only thing kind of close I found was this forum post which suggests someone has made a core for this chip...
http://forum.arduino.cc/index.php?topic=106237.0
...but in the package the Xboards.txt which has the atmega165 entry references to a bootloader called bf_boot.hex which I could not find in the package. Also, I don't think "atmega165" is defined in any other file than this. Am I missing something here?
arduino_atmega165.name=Arduino-Atmega165
arduino_atmega165.upload.protocol=stk500
arduino_atmega165.upload.maximum_size=14336
arduino_atmega165.upload.speed=57600
arduino_atmega165.bootloader.low_fuses=0xE2
arduino_atmega165.bootloader.high_fuses=0x98
arduino_atmega165.bootloader.extended_fuses=0xFF
arduino_atmega165.bootloader.path=atmega
arduino_atmega165.bootloader.file=bf_boot.hex
arduino_atmega165.bootloader.unlock_bits=0x3F
arduino_atmega165.bootloader.lock_bits=0x0F
arduino_atmega165.build.mcu=atmega165
arduino_atmega165.build.f_cpu=8000000L
arduino_atmega165.build.core=arduino
if there is no bootloader installed, you can use a programmer/an arduino to butn the bootloader (the nnn.hex-file)
the code you have shown, goes into the board.txt-file (add it to those already there)
