Help, it's almost Christmas and I'm still fooling around trying to get the boot-loader in place and working on a brand new atmega168v-10pu.
I can get this boot-loader burned(via a Nano as an ISP)) to the chip(ATmegaBOOT_168_pro_8MHz.hex) and it verifies A OK!
I can then burn my sketch to it and it also verifies A OK.
So what's the problem you ask? I can NOT upload any sketch after the first upload without re-burning the boot-loader unless it is the EXACT same sketch. If I make one change, even just commenting out a line of code it no longer verifies and refuses to run at that point.
Even after the initial burn of boot-loader and sketch it works great until I do a reset then nothing!
I have 4 of the atmega168 chips with NO boot-loader on them.
These were supposed to be presents to all of my children for Christmas, please I need help. I know it's probably to late but I like to figure things out myself but this has me pulling my hair out.
The boards.txt file I'm using is attached.
The original boards.txt file was using this boot-loader (ATmegaBOOT_168_atmega328_pro_8MHz.hex) which refused to even load with address errors on line 1. I researched these errors for days with no success.
I'm running out of time, I already have the circuit boards on hand through my own design that fits into a custom case I've done in my wood shop. The project is a simple temp logging with remotes and a 16x2 LCD for displaying the current info and an SD card for logging.
And yes I am a noob to the AVR world as stated in my other post which was of great help furthering this project to completion.
boards.txt (900 Bytes)
