SOLVED, VIEW THE FIX IN THE NEXT REPLY
Hi all.
After reading a bunch of post I couldnt found any fix for my problem:
Playing with my Arduino-NG I followed this topic about how to implement TV Video-Out with Arduino. One step, here, required to upload an HEX file to arduino using avrdude.
Here the hex file:
Here the c source
I uploaded but didn’t work at all. The problem came once I wanted to upload a different sketch using the Arduino application. It was impossible and I got this error message:
Couldn't determine program size: text data bss dec hex filename
avrdude: verification error, first mismatch at byte 0x0002
0x61 != 0x5c
avrdude: verification error; content mismatch
It happens with any sample sketches.
I found some posts about problems uploading code to Arduino and one possible reason is that the bootloader is corrupted, so I pushed the reset button and I got the three blink led light that’s is supposed to get if you have the bootloader burned in the ATMEGA168.
Anyway, I wondered that maybe the bootloader is there, but corrupted, so I tried to load it again using avrdude. That’s what I got:
./avrdude -p m168 -c stk500v1 -P /dev/ttyUSB0 -b 19200 -U flash:w:../bootloaders/atmega/ATmegaBOOT_168_ng.hex
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e9406
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "../bootloaders/atmega/ATmegaBOOT_168_ng.hex"
avrdude: input file ../bootloaders/atmega/ATmegaBOOT_168_ng.hex auto detected as Intel Hex
avrdude: writing flash (16038 bytes):
Writing | ################################################## | 100% 1.30s
avrdude: 16038 bytes of flash written
avrdude: verifying flash memory against ../bootloaders/atmega/ATmegaBOOT_168_ng.hex:
avrdude: load data flash data from input file ../bootloaders/atmega/ATmegaBOOT_168_ng.hex:
avrdude: input file ../bootloaders/atmega/ATmegaBOOT_168_ng.hex contains 16038 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 12.05s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
0xff != 0x0c
avrdude: safemode: Fuses OK
avrdude done. Thank you.
Reading more post I found the people use the AVRISP mkII to program the ATMEGA168, so I bought one with the aim to fix the problem with the same devices about I was reading.
No way.
I got the same error type:
So, at this point I don’t really know what I’m doing (but anyway, I’m learning a lot)
I don’t have big skills on coding, so I feel a little bit lost.
Maybe one way to fix it is erasing completely the flash memory and reload the bootloader… but I don’t really know.
I would really thank any suggestion or useful documentation to fix this problem.
I’m using both Ubuntu linux and OSX 10.5, Arduino 11 and Arduino 15 and I get the same errors in both platforms.
Thanks to all in advance.
Rez
