I'm trying to program an ATMEGA168PA using an arduino Uno as ISP.
I uploaded the "ArduinoISP" code into my arduino Uno, did the
following wirings (http://arduino.cc/en/uploads/Tutorial/SimpleBreadboardAVR.png),
compiled a blink.hex file and this is my avrdude command:
"avrdude -p atmega168p -c avrisp -P COM3 -U lfuse:w:0x62:m -U
hfuse:w:0xdf:m -U efuse:w:0xf9:m -b 19200 -U flash:w:blink.hex"
And here is avrdude output:
Writing | | 0%
0.00s ***failed;
Writing | ################################################## | 100% 0.17s
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0xf9:
avrdude: load data efuse data from input file 0xf9:
avrdude: input file 0xf9 contains 1 bytes
avrdude: reading on-chip efuse data:
Reading | ################################################## | 100% 0.01s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
0xf9 != 0x01
avrdude: verification error; content mismatch
avrdude: safemode: efuse changed! Was f9, and is now 1
Would you like this fuse to be changed back? [y/n]
If I put "n", it stops here and nothing is done.
If I put "y", it goes to an infinite loop.
With -vvvv flag, here is the infinite loop showed:
avrdude: Send: V [56] . [ac] . [a4] . [00] . [01] [20]
avrdude: Recv: . [14]
avrdude: Recv: . [00]
avrdude: Recv: . [10]
avrdude: Send: V [56] P [50] . [08] . [00] . [00] [20]
avrdude: Recv: . [f9]
etc...
Where did I go wrong ?
Many thanks in advance
