ATmega2560-Arduino Pin Mapping
Hi Community,
in the last days i am working on an project using the Arduino Mega 2560. On planning my Pin using i found some bugs in the ATmega2560-Arduino Pin Mapping.
if i get it right there are some labels (such as PWM) in the ‘Mapped Pin Name’ at the wrong row ( its an mixed up which pin numbers are the right one…)
in the Attachment is an OpenOffice Calc and PDF file with the corrected Table. ( I hope so :wink: )
I will also post it here as tab separated table :
Arduino Mega 2560 PIN mapping table
ATmega 2560 Pin out					Arduino Mega
		Function
NR	Name	Function	Function	Function	Mapped Pin Name	Function	Function	Datasheet
1	PG5	OC0B			Digital pin 04	PWM
2	PE0	RXD0	PCINT8		Digital pin 00		RX0	(USART0 Receive Pin, Programming Data Input or Pin Change Interrupt 8)
3	PE1	TXD0			Digital pin 01		TX0	(USART0 Transmit Pin or Programming Data Output)
4	PE2	XCK0	AIN0					(USART0 External Clock  Input/Output)
5	PE3	OC3A	AIN1		Digital pin 05	PWM
6	PE4	OC3B	INT4		Digital pin 02	PWM
7	PE5	OC3C	INT5		Digital pin 03	PWM
8	PE6	T3	INT6
9	PE7	CLKO	INT7	ICP3
10	VCC	VCC
11	GND	GND
12	PH0	RXD2			Digital pin 17		RX2	(USART2 Receive Pin)
13	PH1	TXD2			Digital pin 16		TX2	(USART2 Transmit Pin)
14	PH2	XCK2						(USART2 External Clock  Input/Output)
15	PH3	OC4A			Digital pin 06	PWM
16	PH4	OC4B			Digital pin 07	PWM
17	PH5	OC4C			Digital pin 08	PWM
18	PH6	OC2B			Digital pin 09	PWM
19	PB0	SS	PCINT0		Digital pin 53		SS	(SPI Slave Select input or Pin Change Interrupt 0)
20	PB1	SCK	PCINT1		Digital pin 52		SCK	(SPI Bus Serial Clock or Pin Change Interrupt 1)
21	PB2	MOSI	PCINT2		Digital pin 51		MOSI	(SPI Bus Master Output/Slave Input or Pin Change Interrupt 2)
22	PB3	MISO	PCINT3		Digital pin 50		MISO	(SPI Bus Master Input/Slave Output or Pin Change Interrupt 3)
23	PB4	OC2A	PCINT4		Digital pin 10	PWM
24	PB5	OC1A	PCINT5		Digital pin 11	PWM
25	PB6	OC1B	PCINT6		Digital pin 12	PWM
26	PB7	OC0A	PCINT7	OC1C	Digital pin 13	PWM
27	PH7	T4
28	PG3	TOSC2
29	PG4	TOSC1
30	RESET	RESET
31	VCC	VCC
32	GND	GND
33	XTAL2	XTAL2
34	XTAL1	XTAL1
35	PL0	ICP4			Digital pin 49
36	PL1	ICP5			Digital pin 48
37	PL2	T5			Digital pin 47
38	PL3	OC5A			Digital pin 46	PWM
39	PL4	OC5B			Digital pin 45	PWM
40	PL5	OC5C			Digital pin 44	PWM
41	PL6				Digital pin 43
42	PL7				Digital pin 42
43	PD0	SCL	INT0		Digital pin 21	SCL		(TWI Serial Clock or External Interrupt0 Input)
44	PD1	SDA	INT1		Digital pin 20	SDA		(TWI Serial Data or External Interrupt1 Input )
45	PD2	RXD1	INT2		Digital pin 19		RX1	(USART1 Receive Pin or External Interrupt2 Input)
46	PD3	TXD1	INT3		Digital pin 18		TX1	(USART1 Transmit Pin or External Interrupt3 Input)
47	PD4	ICP1
48	PD5	XCK1						(USART1 External Clock  Input/Output)
49	PD6	T1
50	PD7	T0			Digital pin 38
51	PG0	WR			Digital pin 41
52	PG1	RD			Digital pin 40
53	PC0	A8			Digital pin 37
54	PC1	A9			Digital pin 36
55	PC2	A10			Digital pin 35
56	PC3	A11			Digital pin 34
57	PC4	A12			Digital pin 33
58	PC5	A13			Digital pin 32
59	PC6	A14			Digital pin 31
60	PC7	A15			Digital pin 30
61	VCC	VCC
62	GND	GND
63	PJ0	RXD3	PCINT9		Digital pin 15		RX3	(USART3 Receive Pin or Pin Change Interrupt 9)
64	PJ1	TXD3	PCINT10		Digital pin 14		TX3	(USART3 Transmit Pin or Pin Change Interrupt 10)
65	PJ2	XCK3	PCINT11					(USART3 External Clock  Input/Output or Pin Change Interrupt 11)
66	PJ3		PCINT12
67	PJ4		PCINT13
68	PJ5		PCINT14
69	PJ6		PCINT 15
70	PG2	ALE			Digital pin 39
71	PA7	AD7			Digital pin 29
72	PA6	AD6			Digital pin 28
73	PA5	AD5			Digital pin 27
74	PA4	AD4			Digital pin 26
75	PA3	AD3			Digital pin 25
76	PA2	AD2			Digital pin 24
77	PA1	AD1			Digital pin 23
78	PA0	AD0			Digital pin 22
79	PJ7
80	VCC	VCC
81	GND	GND
82	PK7	ADC15	PCINT23		Analog pin 15
83	PK6	ADC14	PCINT22		Analog pin 14
84	PK5	ADC13	PCINT21		Analog pin 13
85	PK4	ADC12	PCINT20		Analog pin 12
86	PK3	ADC11	PCINT19		Analog pin 11
87	PK2	ADC10	PCINT18		Analog pin 10
88	PK1	ADC9	PCINT17		Analog pin 09
89	PK0	ADC8	PCINT16		Analog pin 08
90	PF7	ADC7	PCINT15		Analog pin 07
91	PF6	ADC6	PCINT14		Analog pin 06
92	PF5	ADC5	TMS		Analog pin 05
93	PF4	ADC4	TMK		Analog pin 04
94	PF3	ADC3			Analog pin 03
95	PF2	ADC2			Analog pin 02
96	PF1	ADC1			Analog pin 01
97	PF0	ADC0			Analog pin 00
98	AREF				Analog Reference
99	GND	GND
100	AVCC	VCC
is this forum the right way to get such corrections to the side?
have fun and sunny greetings
Stefan
Arduino_Mega2560_R3__PinMapping_v05.pdf (21.3 KB)
Arduino_Mega2560_R3__PinMapping_v05.ods (487 KB)
