atMEGA2560 based standalone design on custom board
Hello there,
I’m building a robotics project where I require 10 PWM outputs driving proportional hydraulics.
I decided to use the atMEGA2560 for this and used FuzzyStudio’s bare minimum design as a guide.
A second set of knowledgeable eyes is hugely valuable and so I would appreciate if some of you could have a quick look at the schematic to see if I missed anything to get the 2560 to run.
I’ve attached a .jpg of the schematic.
I will be using an Uno to flash the bootloader and a CP2102 USB-TTL Serial converter as a programmer.
Thanks
R201 valued 1M,can be deleted
