Atmega2560 r2 What is boot start address
Hello, I try to make a bootloader for my Atmega2560 r2 Fuses are low FF, high D8, Ext FF Lock bits are 0F
option for link is : -Wl,--section-start=.text=0x1F000
Is 1F000 good for a 8kb bootloader?
Thank you.
See the datasheet. Table 30-4 shows High Byte fuse bits 2,1 select the boot size. With the bits at 0 0, Table 29-7 says 4096 works (8192 bytes), occupying:
0x7000 - 0x7FFF
Ok I saw datasheet.
I tried with 0x7000, without success.
I also tried 0xE000 witch is 7000 * 2, without success...
I don't understand why 7000? Atmega 2560 has 256Kb of flash. 256*1024 = 262144, if 8Kb is removed at the end, it's 262144-(8*1024) = 253952, it's 0x3E000, divided by 2 (word access) it's 0x1F000.
I tried also 1F000, it's always the same result, program boots always at 0.
Then I tried 3E000 and it works fine.
Thank you for all
