ATmega324, The Quest of a Bootloader
First a bit of background:
I have an ATmega324a MCU (should be the same as the p and pa variant) with a 8 MHz crystal (should use 18 pF caps, I've put 15 pF).
It runs on 5V (supplied by a working Arduino Duemilanove). I have a test LED on PA7, USART0 on PD0/PD1 connected to MAX232 to a real serial port /dev/ttyS0.
I can program the ATmega324a without problems via ISP (using Arduino on /dev/ttyUSB0 as the avrisp) as well as I've tested the serial communication in both direction by means of a short sketch, which replies after 1 second what I've written to ATmega324a. If I make a sketch for blinking the LED, it blinks in correct intervals. My fuses are lfuse: 0xFF, hfuse: 0xD8, efuse: 0x04. To the serial port I've connected only three wires: Rx, Tx, GND.
My problem:
Can't get a bootloader to work, so that I could upload code via serial port instead of ISP.
What I've tried:
I've added to optiboot files in /usr/share/arduino/hardware/arduino/bootloaders/optiboot/ the following things:
To optiboot.c:
#if defined(__AVR_ATmega324A__)
/* Onboard LED is connected to pin PB5 in Arduino NG, Diecimila, and Duemilanove */
#define LED_DDR     DDRA
#define LED_PORT    PORTA
#define LED_PIN     PINA
#define LED         PINA7
/* Ports for soft UART */
#ifdef SOFT_UART
#define UART_PORT   PORTD
#define UART_PIN    PIND
#define UART_DDR    DDRD
#define UART_TX_BIT 1
#define UART_RX_BIT 0
#endif
#endif
To Makefile:
atmega324: TARGET = atmega324
atmega324: MCU_TARGET = atmega324a
atmega324: CFLAGS += '-DLED_START_FLASHES=3' '-DBAUD_RATE=115200'
atmega324: AVR_FREQ = 8000000L
atmega324: LDSECTION  = --section-start=.text=0x7e00
atmega324: $(PROGRAM)_atmega324.hex
atmega324: $(PROGRAM)_atmega324.lst
atmega324_isp: atmega324
atmega324_isp: TARGET = atmega324a
atmega324_isp: HFUSE = DE # 2.7V brownout
atmega324_isp: LFUSE = FF # Internal 8MHz osc (8MHz) Slow rising power
atmega324_isp: EFUSE = FC # 512 byte boot
atmega324_isp: isp
I've also added to boards.txt in /usr/share/arduino/hardware/arduino:
atmega324.name=Atmega324a
atmega324.upload.protocol=arduino
atmega324.upload.maximum_size=32256
atmega324.upload.speed=115200
atmega324.bootloader.low_fuses=0xff
atmega324.bootloader.high_fuses=0xd8
atmega324.bootloader.extended_fuses=0xfc
atmega324.bootloader.path=optiboot
atmega324.bootloader.file=optiboot_atmega324.hex
atmega324.bootloader.unlock_bits=0x3F
atmega324.bootloader.lock_bits=0x0F
atmega324.build.mcu=atmega324p
atmega324.build.f_cpu=8000000L
atmega324.build.core=arduino
And modified the Arduino IDE's avrdude.conf:
signature        = 0x1e 0x95 0x08; (at m324p)
to
signature	     = 0x1e 0x95 0x15;
I then compiled the bootloader by means of: sudo make -t Makefile atmega324
It created the hex., which I've uploaded successfully with:
avrdude -P /dev/ttyUSB0 -b 19200 -c avrisp -p m328p -F -v -U flash:w:optiboot_atmega324.hex -U lock:w:0x0F:m
I use -F because I haven't modified the /etc/avrdude.conf.
The LED flashes 3 times.
If I try now avrdude -P /dev/ttyS0 -b 115200 -c arduino -p m328p -F -v -v -U flash:w:optiboot_atmega324.hex
I get:
avrdude: Version 5.10, compiled on Jun 29 2010 at 03:44:14
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/etc/avrdude.conf"
User configuration file is "/root/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyS0
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: ser_recv(): programmer is not responding
avrdude done. Thank you.
I've also tried burning the bootloader from Arduino IDE. Selecting the board "atmega324a", serial port /dev/ttyUSB0 and Burn Bootloader w/Arduino as ISP.
It works without problems and at the end the LED of ATmega324a flashes. If I now select the /dev/ttyS0 and try to upload the Blink sketch I get the "programmer is not responding" error.
Please show me where have I failed.
It's questionable whether 115200bps works at 8MHz. Try a lower bitrate.
Without DTR/etc, you'll need to do a manual reset, which is a close thing with the existing 1s timeout.
westfw:
Ok modified Makefile to:
atmega324: CFLAGS += '-DLED_START_FLASHES=5' '-DBAUD_RATE=9600'
Recompiled with "make -l Makefile atmega324".
Uploaded to atmega324a via avrdude, led flashed 5 times.
Holding GND to Reset (i have no pullup on Reset, but it doesn't cause any problems I think) I press enter in the terminal invoking this:
avrdude -P /dev/ttyS0 -b 9600 -c arduino -p m328p -F -v -v -v -v -U flash:w:Blink.cpp.hex
When I see in the terminal screen "avrdude: Send: 0 [30] [20]" I immediately disconnect GND from Reset and then this happens (didn't post everything, just the start):
avrdude: Recv: . [14]
avrdude: Recv: . [10]
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 5 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
avrdude: Send: A [41] . [80] [20]
avrdude: Recv: . [03]
avrdude: Send: A [41] . [81] [20]
avrdude: Send: A [41] . [82] [20]
After it's done, you are greeted with a "Thank you" from avrdude and the LED magically starts to blink in a repetitive 1s interval.
Thank you for your help, it works.
