Atmega328/Arduino - Timer 1 (mode 4 and 12)
Hi
I cannot understand why this is not interrupting at 1Hz:
  DDRB |= B00100000; // pin 13 output
  PORTB &= ~B00100000; // pin 13 LOW
  cli();
  TCNT1 = 0;
  OCR1A = 15624; // = 16M / (1Hz * 1024) - 1
  TCCR1A = 0;
  TCCR1B = 0;
  TCCR1B |= _BV(WGM12); // mode 4 => CTC with TOP=OCR1A
  TCCR1B |= _BV(CS12) | _BV(CS10); // 1024 prescaler
  TIMSK1 |= _BV(OCIE1A); // activate interrupt when TCNT1=OCR1A
  sei();
ISR(TIMER1_COMPA_vect){ // should interrupt @1Hz (but is right now above 1kHz)
  PORTB ^= B00100000; // switch pin 13
That is using Mode 4 of Timer1, it calls the interrupt but a lot faster (above 1kHz).
Trying to use Mode 12 works fine
  cli();
  TCNT1 = 0;
  ICR1 = 15624; // = 16M / (1Hz * 1024) - 1
  TCCR1A = 0;
  TCCR1B = 0;
  TCCR1B |= _BV(WGM12) | _BV(WGM13); // mode 12 => CTC with TOP=ICR1
  TIMSK1 |= _BV(ICIE1); // activate interrupt when TCNT=ICR1
  sei();
ISR(TIMER1_CAPT_vect){ // interrupts @1Hz
Hoping someone can clarify what I missed here!
Thank you in advance!
PS: I am not trying to switch the LED 13 on and off - this is just so I can see whether the timer is working or not
Sooo I found the answer myself!
  TCCR1A = 0;
  TCCR1B = 0;
does not work (same as above), but the following works!
  TCCR1A = 0;
  TCCR1B = 0;
I guess the value of OCR1A is reset when the TCCR1x registers are reset?!
