Hello all.
Is it possible to run a Atmega328 at 4 MHz or even lower to save battery power?
Would the arduino code work like on a 16 MHz Atmega328 ?
MrMcChicken:
Hello all.
Yes, absolutely. I've used 1MHz and I believe the internal 128kHz oscillator can also be used as a system clock, but I've read that is probably beyond the point of diminishing returns. Additional entries in the boards.txt file will be needed for alternate clock frequencies. I don't try to use a bootloader below 8MHz, and if using the internal 8MHz oscillator (either direct or divided), it may not be accurate enough for serial comm without some tuning.
Yes.
Thanks a lot!
can you share the board.tx file used? great to have a 4mhz working arduino, but even better if you still can program it with arduino IDE!
