You do have a 16MHz crystal and 2 22pF caps, or a 16 MHz resonator, attached? Uno as board type requires an external oscillator. Also a good idea for proper operation is 10K pullup resistor from Reset to +5V, and 0.1uF caps from VCC and AVCC to Gnd, and from Aref to Gnd.
Connect +5V to VCC and AVCC. Do Not connect to Aref, that is connected internally.
Hi, Crossroads.
Thank for your reply.
I attach my schematics.
My pro mini is 8Mhz 3.3V. And I use 8Mhz crystal with 18pF caps, 10K pullup resistor, 0.1uF caps form AREF to GND, VCC to GND( not include the schematics but done), AVCC to GND( not include the schematics but done).
The schematics is same with usual promini schematics.
I was try to change the signature 0x0F to 0x14, But error was occur. T.T
You do have a Programmer connected, yes? It connects to SCK, MISO, MOSI, Reset, Power, Gnd, and accesses the memory directly to load the bootloader.
I don't see an ICSP header. You can use a Programmer and a press-on adapter like this to load the bootloader.
