Atmega328: Frequency vs min voltage
As per Atmega328P datasheet the min voltage for 10MHz is 2.7Volts.
Is it okay to use 16MHz xtal, divide by 4 in code ie run the MCU at 4MHz and power by 2.7Volts source?
In other words the "Maximum Frequency vs. VCC curve is" MCU frequency or xtal frequency?
Thanks,
WI
But would not the code to change the clock to divide by 4 be running at 16Mhz at the start ?
As I recall dont you have to set the fuse to divide the clock by 8 (2Mhz) and then run the code to change the clock divisor ?
srnet:
Yes it would. However, the device in question is a battery operated device which runs on 2 AA cells (at 3.1V) at bootup. The code uses CLKPR to divide by 4 and from then on the device always runs at 4MHz as the battery begins to drain. My question was more about the internal oscillator hardware, to be precise, can it run off a 16Mhz xtal and generate the 4MHz for MCU at 2.7V?
srnet:
Yes, alternatively, CLKPR can be set to do the clock division. My app does this.
