ATMega328-PU (No Pico-Power)
After purchasing two ATMega328 chips from Digikey, I realized that I did not buy the ATMega328P. I looked at forums and decided that I could use the common workaround. (changing the signature in the avrdude.conf file) I tried this, and some other solutions I found online, and I still got the Invalid Device signature error.
This is the verbose output I am getting:
         System wide configuration file is "/Users/MyUsername/Downloads/Arduino copy.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/MyUsername/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/cu.usbmodemfa1311
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.04s
avrdude: Device signature = 0x000000 (retrying)
Reading | ################################################## | 100% 0.02s
Error while burning bootloader.
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
avrdude done.  Thank you.
Here is the .conf file after the ATMega328 heading
# ATmega328
part
    id			= "m328";
    desc		= "ATmega328";
    has_debugwire	= yes;
    flash_instr		= 0xB6, 0x01, 0x11;
    eeprom_instr	= 0xBD, 0xF2, 0xBD, 0xE1, 0xBB, 0xCF, 0xB4, 0x00,
			  0xBE, 0x01, 0xB6, 0x01, 0xBC, 0x00, 0xBB, 0xBF,
			  0x99, 0xF9, 0xBB, 0xAF;
    stk500_devcode	= 0x86;
    # avr910_devcode	= 0x;
    signature		= 0x1e 0x95 0x14;
    pagel		= 0xd7;
    bs2			= 0xc2;
    chip_erase_delay	= 9000;
    pgm_enable = "1 0 1 0 1 1 0 0 0 1 0 1 0 0 1 1",
		 "x x x x x x x x x x x x x x x x";
    chip_erase = "1 0 1 0 1 1 0 0 1 0 0 x x x x x",
    timeout	= 200;
    stabdelay	= 100;
    cmdexedelay	= 25;
    synchloops	= 32;
    bytedelay	= 0;
    pollindex	= 3;
    pollvalue	= 0x53;
    predelay	= 1;
    postdelay	= 1;
    pollmethod	= 1;
    pp_controlstack =
	0x0E, 0x1E, 0x0F, 0x1F, 0x2E, 0x3E, 0x2F, 0x3F,
	0x4E, 0x5E, 0x4F, 0x5F, 0x6E, 0x7E, 0x6F, 0x7F,
	0x66, 0x76, 0x67, 0x77, 0x6A, 0x7A, 0x6B, 0x7B,
	0xBE, 0xFD, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00;
    hventerstabdelay	= 100;
    progmodedelay	= 0;
    latchcycles		= 5;
    togglevtg		= 1;
    poweroffdelay	= 15;
    resetdelayms	= 1;
    resetdelayus	= 0;
    hvleavestabdelay	= 15;
    resetdelay		= 15;
    chiperasepulsewidth	= 0;
    chiperasepolltimeout = 10;
    programfusepulsewidth = 0;
    programfusepolltimeout = 5;
    programlockpulsewidth = 0;
    programlockpolltimeout = 5;
    ocdrev              = 1;
    memory "eeprom"
	paged		= no;
	page_size	= 4;
	size		= 1024;
	min_write_delay = 3600;
	max_write_delay = 3600;
	readback_p1	= 0xff;
	readback_p2	= 0xff;
	read = " 1 0 1 0 0 0 0 0",
	       " 0 0 0 x x x a9 a8",
	       " a7 a6 a5 a4 a3 a2 a1 a0",
	       " o o o o o o o o";
	write = " 1 1 0 0 0 0 0 0",
		" i i i i i i i i";
	loadpage_lo = " 1 1 0 0 0 0 0 1",
		      " 0 0 0 0 0 0 0 0",
		      " 0 0 0 0 0 0 a1 a0",
		      " i i i i i i i i";
	writepage = " 1 1 0 0 0 0 1 0",
		    " 0 0 x x x x a9 a8",
		    " a7 a6 a5 a4 a3 a2 0 0",
		    " x x x x x x x x";
	mode		= 0x41;
	delay		= 20;
	blocksize	= 4;
	readsize	= 256;
    memory "flash"
	paged		= yes;
	size		= 32768;
	page_size	= 128;
	num_pages	= 256;
	min_write_delay = 4500;
	max_write_delay = 4500;
	readback_p1	= 0xff;
	readback_p2	= 0xff;
	read_lo = " 0 0 1 0 0 0 0 0",
		  " 0 0 a13 a12 a11 a10 a9 a8",
		  " o o o o o o o o";
	read_hi = " 0 0 1 0 1 0 0 0",
		  " o o o o o o o o";
	loadpage_lo = " 0 1 0 0 0 0 0 0",
		      " 0 0 0 x x x x x",
		      " x x a5 a4 a3 a2 a1 a0",
		      " i i i i i i i i";
	loadpage_hi = " 0 1 0 0 1 0 0 0",
		      " 0 0 0 x x x x x",
		      " i i i i i i i i";
	writepage = " 0 1 0 0 1 1 0 0",
		    " a7 a6 x x x x x x",
		    " x x x x x x x x";
	mode		= 0x41;
	delay		= 6;
	blocksize	= 128;
	readsize	= 256;
    memory "lfuse"
	size = 1;
	read = "0 1 0 1 0 0 0 0 0 0 0 0 0 0 0 0",
	       "x x x x x x x x o o o o o o o o";
	write = "1 0 1 0 1 1 0 0 1 0 1 0 0 0 0 0",
	      	"x x x x x x x x i i i i i i i i";
    memory "hfuse"
	size = 1;
	read = "0 1 0 1 1 0 0 0 0 0 0 0 1 0 0 0",
	write = "1 0 1 0 1 1 0 0 1 0 1 0 1 0 0 0",
    memory "efuse"
	size = 1;
	read = "0 1 0 1 0 0 0 0 0 0 0 0 1 0 0 0",
	       "x x x x x x x x x x x x x o o o";
	write = "1 0 1 0 1 1 0 0 1 0 1 0 0 1 0 0",
	      	"x x x x x x x x x x x x x i i i";
    memory "lock"
	size = 1;
	read = "0 1 0 1 1 0 0 0 0 0 0 0 0 0 0 0",
	       "x x x x x x x x x x o o o o o o";
	write = "1 0 1 0 1 1 0 0 1 1 1 x x x x x",
	      	"x x x x x x x x 1 1 i i i i i i";
    memory "calibration"
	size = 1;
	read = "0 0 1 1 1 0 0 0 0 0 0 x x x x x",
	       "0 0 0 0 0 0 0 0 o o o o o o o o";
    memory "signature"
	size = 3;
	read = "0 0 1 1 0 0 0 0 0 0 0 x x x x x",
	       "x x x x x x a1 a0 o o o o o o o o";
part parent "m328"
    id			= "m328p";
    desc		= "ATmega328P";
    ocdrev              = 1;
Any help would be great! I am at a loss. Hopefully it is really obvious to someone who is not me, and they will tell me what is wrong, but as for now, I am at a loss.
Thanks!
You’re not getting a valid signature at all. 0 usually means some sort of wiring error.
Sometimes, an editor will mess up that file. Try editing again, or use a file compare program to ensure you only made the changes expected.
I use Winmerge, but there are many others.
Ray
Well I checked the wiring and it all checked out, but on a whim I tried using my uno's power instead of the supply I built myself. It worked finally. I guess I'll have to check out what's going wrong. Thanks for the help!
Topher
