atmega328 sleep and watchdog
First post :slight_smile:
I’m creating a customised atmega328 board (same chip as Pro Mini). I use 2 pins - D2 and D3 - as external interrupts to wake up from sleep. Since good reliability is required, i’ve added a watchdog for code lockup protection. The device will run on batteries and never powered down.
How does this look?
#include <avr/sleep.h>
#include <avr/power.h>
#include <avr/wdt.h>
#include <avr/interrupt.h>    // Needed to use interrupts
volatile int int0_flag;
volatile int int1_flag;
#define TRUE 1
#define FALSE 0
ISR(INT0_vect)
    int0_flag = TRUE;
ISR(INT1_vect)
    int1_flag = TRUE;
void sleepNow()
    wdt_disable();
    byte adcsra_save = ADCSRA;
    ADCSRA = 0;  // disable ADC
    power_all_disable ();   // turn off all modules
    set_sleep_mode (SLEEP_MODE_PWR_DOWN);   // sleep mode is set here
    noInterrupts();
    sleep_enable();
    interrupts();
    sleep_cpu ();            // now goes to Sleep and waits for the interrupt
    sleep_disable ();      // precaution
    ADCSRA = adcsra_save;  // stop power reduction
    power_all_enable ();   // turn on all modules
    //enable watchdog to check for code lockups
    wdt_enable(WDTO_8S);
}  // end of sleepNow
   Serial.println("starting...");
   pinMode(2, INPUT);
   pinMode(3, INPUT);
   digitalWrite(2, HIGH);
   digitalWrite(3, HIGH);
   EICRA = B00001010; // configure pin 2 and 3 for falling
   EIMSK = B00000011; // mask for INT1 and INT0
   int1_flag = FALSE;
   int0_flag = FALSE;
   Serial.println("ready...");
       if (int0_flag == TRUE)
            Serial.println("wake up from INT0");
            int0_flag = FALSE;
       if (int1_flag == TRUE)
            Serial.println("wake up from INT1");
            int1_flag = FALSE;
       Serial.println("1");
       Serial.println("2");
       Serial.println("3");
       sleepNow();
       //while (1)
Cheers
Does anyone have an answer?
Cheers
How does this look?
Looks good :slight_smile: I did not check every detail. Why don't you just try it on your board? Does it work?
I tested it on a board and it appears to work fine.
As i need very high reliability, i just want to make sure there is no chance that any problems can arise when never powering it down and running on batteries.
Thanks
