Hi to everyone!
I need to upload a sketch to Atmega328 placed on my custom PCB using ICSP, but I've got some problems.
The micro works perfectly when I plug it into my Uno board and I upload the sketch directly.
When I try instead, to use ICSP to load a sketch from Arduino Uno connected to my computer to my custom board, the upload fails.
To cable the ICSP i followed this guide from Sparkfun.
I double-checked the PCB routes, the jumper wires connections ICSP to ICSP and the Arduino IDE settings.
IDE settings under "Tools" menu:
Board: Arduino/Genuino Uno
Port: /dev/cu.usbmodem1421 Arduino/Genuino Uno
Programmer: Arduino as ISP
Is there someone who knows how to solve this problem?
The error I get is:
Arduino:1.6.5 (Mac OS X), Scheda:"Arduino/Genuino Uno"
Lo sketch usa 1.030 byte (3%) dello spazio disponibile per i programmi. Il massimo è 32.256 byte.
Le variabili globali usano 9 byte (0%) di memoria dinamica, lasciando altri 2.039 byte liberi per le variabili locali. Il massimo è 2.048 byte.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Problema di caricamento sulla scheda. Guarda http://www.arduino.cc/en/Guide/Troubleshooting#upload per suggerimentiQuesto report potrebbe essere più ricco
di informazioni con
"Mostra un output dettagliato durante la compilazione"
abilitato in "File > Impostazioni"
