Did you do "burn bootloader" to set the fuses to tell it to run at 8mhz, or do you still have it connected to a 16mhz crystal and running at that speed?
I didn't burn a bootloader, I burnt the sketch direct using a USBTiny ISP.
There is a 16MHz crystal connected but I figured that wouldn't matter as the fuses should set it so those pins aren't connected internally to the clocking.
RichardS72:
Uploading the sketch does not set the fuses, even via ISP.
Use burn bootloader to set the fuses - even if you're not using a bootloader (and even on boards that don't have a bootloader), you still need to do "burn bootloader" to set the fuses.
