tubos
May 25, 2023, 6:16pm
1
I have a very low current circuit with a barebone atmega328 running at 4Mhz.
Its powered by a cr2032 , it sleeps most of the time 4uA and consuming 250uA from my lcd.
I would like to add a DS18B20 that consumes 1.5mA for a short time and sleep again.
The problem is the DS18b20 mini voltage is 3V i dont know if it goes lower.
What can be my options to still use a cr2032 ( i like it to be a small footprint)
lowpower Boost or step-up circuit ? or would the cr2032 still work at 2.7 or 2.8v?
Maybe with Dickson charge pump.
A voltage doubler is an electronic circuit which charges capacitors from the input voltage and switches these charges in such a way that, in the ideal case, exactly twice the voltage is produced at the output as at its input. The simplest of these...
tubos
May 27, 2023, 9:45am
3
Thanks , good tip
I've done some experiments with a cr2032 at 2.8v the DS18B20 still seems to work reliable.
@barshatriplee , why do you think that the OP needs a 5V supply? They are using a barebones 328P which can run quite happily at lower voltages (and lower clock speeds).
tubos
May 27, 2023, 10:48am
6
Sorry this is bad advice , did you actually read and understand the topic post?
system
Closed
November 23, 2023, 10:49am
7
