just thought i'd share this finding. If encountering this error "Starting Program Mode - Failed, result = 0x0" when trying to run through the instructions at:
http://3g1l.com/blog-burn-bootloader-blank-atmega328atmega328p-arduino-uno
just add add a 16mhz crystal or 8mhz crystal to pins 7 & 8 of the atmega328p. for some reason it worked with 16mhz on first try to burn a bootloader, but on second try i was getting that error message. thats when i tried an 8mhz crystal and to my surprise worked out fine.
below serial msg from using 8mhz crystal:
OptiLoader Bootstrap programmer.
2011 by Bill Westfield (WestfW)
Target power on! ...
Starting Program Mode [OK]
Reading signature:950F
Searching for image...
Found "optiboot_atmega328.hex" for atmega328P
Start address at 7E00
Total bytes read: 502
Setting fuses for programming
Lock: 3F ABE000 Low: FF ABA000 High: DE ABA800 Ext: 5 ABA400
Programming bootloader: 512 bytes at 0x3F00
Commit Page: 3F00:4C3F00
Commit Page: 3F40:4C3F40
Commit Page: 3F80:4C3F80
Commit Page: 3FC0:4C3FC0
Restoring normal fuses
Lock: 2F ABE000
Target power OFF!
Type 'G' or hit RESET for next chip
