EDIT: AVR-LIBC Version is 2.0.0-3
The exact call is like the following:
avr-g++ -c -std=gnu++17 -Os -Wall -Wextra -Wpedantic -Iinc -mmcu=atmega328p src/main.cc -o src/main.o
avr-g++ -Os -mmcu=atmega328p src/main.o -o build/app.elf
avr-objcopy -O ihex -j .bss -j .data -j .text build/app.elf build/app.hex
avrdude -v -e -c stk500 -p atmega328p -P /dev/ttyACM0 -U flash:w:build/app.hex:a
That's what is called when flashing the program. I noticed sometimes it seems like the flashing progress changes the fuses.. I doesn't happen everytime but when it does it shows the following message:
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: safemode: hfuse reads as 58
avrdude: safemode: efuse reads as 50
avrdude: safemode: lfuse changed! Was d6, and is now 50
Would you like this fuse to be changed back? [y/n]
avrdude: safemode: hfuse changed! Was df, and is now 58
avrdude: safemode: efuse changed! Was ff, and is now 50
avrdude: safemode: Fuses OK (E:FF, H:DF, L:D6)
The disassembled code looks like this:
app.elf: file format elf32-avr
Disassembly of section .text:
00000000 <__vectors>:
0: 0c 94 34 00 jmp 0x68 ; 0x68 <__ctors_end>
4: 0c 94 46 00 jmp 0x8c ; 0x8c <__bad_interrupt>
8: 0c 94 46 00 jmp 0x8c ; 0x8c <__bad_interrupt>
c: 0c 94 46 00 jmp 0x8c ; 0x8c <__bad_interrupt>
10: 0c 94 46 00 jmp 0x8c ; 0x8c <__bad_interrupt>
14: 0c 94 46 00 jmp 0x8c ; 0x8c <__bad_interrupt>
18: 0c 94 46 00 jmp 0x8c ; 0x8c <__bad_interrupt>
1c: 0c 94 46 00 jmp 0x8c ; 0x8c <__bad_interrupt>
20: 0c 94 46 00 jmp 0x8c ; 0x8c <__bad_interrupt>
24: 0c 94 46 00 jmp 0x8c ; 0x8c <__bad_interrupt>
28: 0c 94 46 00 jmp 0x8c ; 0x8c <__bad_interrupt>
2c: 0c 94 46 00 jmp 0x8c ; 0x8c <__bad_interrupt>
30: 0c 94 46 00 jmp 0x8c ; 0x8c <__bad_interrupt>
34: 0c 94 46 00 jmp 0x8c ; 0x8c <__bad_interrupt>
38: 0c 94 46 00 jmp 0x8c ; 0x8c <__bad_interrupt>
3c: 0c 94 46 00 jmp 0x8c ; 0x8c <__bad_interrupt>
40: 0c 94 48 00 jmp 0x90 ; 0x90 <__vector_16>
44: 0c 94 46 00 jmp 0x8c ; 0x8c <__bad_interrupt>
48: 0c 94 46 00 jmp 0x8c ; 0x8c <__bad_interrupt>
4c: 0c 94 46 00 jmp 0x8c ; 0x8c <__bad_interrupt>
50: 0c 94 46 00 jmp 0x8c ; 0x8c <__bad_interrupt>
54: 0c 94 46 00 jmp 0x8c ; 0x8c <__bad_interrupt>
58: 0c 94 46 00 jmp 0x8c ; 0x8c <__bad_interrupt>
5c: 0c 94 46 00 jmp 0x8c ; 0x8c <__bad_interrupt>
60: 0c 94 46 00 jmp 0x8c ; 0x8c <__bad_interrupt>
64: 0c 94 46 00 jmp 0x8c ; 0x8c <__bad_interrupt>
00000068 <__ctors_end>:
68: 11 24 eor r1, r1
6a: 1f be out 0x3f, r1 ; 63
6c: cf ef ldi r28, 0xFF ; 255
6e: d8 e0 ldi r29, 0x08 ; 8
70: de bf out 0x3e, r29 ; 62
72: cd bf out 0x3d, r28 ; 61
00000074 <__do_clear_bss>:
74: 21 e0 ldi r18, 0x01 ; 1
76: a0 e0 ldi r26, 0x00 ; 0
78: b1 e0 ldi r27, 0x01 ; 1
7a: 01 c0 rjmp .+2 ; 0x7e <.do_clear_bss_start>
0000007c <.do_clear_bss_loop>:
7c: 1d 92 st X+, r1
0000007e <.do_clear_bss_start>:
7e: a2 30 cpi r26, 0x02 ; 2
80: b2 07 cpc r27, r18
82: e1 f7 brne .-8 ; 0x7c <.do_clear_bss_loop>
84: 0e 94 6c 00 call 0xd8 ; 0xd8 <main>
88: 0c 94 7a 00 jmp 0xf4 ; 0xf4 <_exit>
0000008c <__bad_interrupt>:
8c: 0c 94 6a 00 jmp 0xd4 ; 0xd4 <__vector_default>
00000090 <__vector_16>:
90: 1f 92 push r1
92: 1f b6 in r1, 0x3f ; 63
94: 1f 92 push r1
96: 11 24 eor r1, r1
98: 2f 93 push r18
9a: 8f 93 push r24
9c: 9f 93 push r25
9e: 80 91 00 01 lds r24, 0x0100 ; 0x800100 <_edata>
a2: 90 91 01 01 lds r25, 0x0101 ; 0x800101 <_edata+0x1>
a6: 01 96 adiw r24, 0x01 ; 1
a8: 90 93 01 01 sts 0x0101, r25 ; 0x800101 <_edata+0x1>
ac: 80 93 00 01 sts 0x0100, r24 ; 0x800100 <_edata>
b0: 81 3a cpi r24, 0xA1 ; 161
b2: 97 40 sbci r25, 0x07 ; 7
b4: 40 f0 brcs .+16 ; 0xc6 <__vector_16+0x36>
b6: 8b b1 in r24, 0x0b ; 11
b8: 90 e2 ldi r25, 0x20 ; 32
ba: 89 27 eor r24, r25
bc: 8b b9 out 0x0b, r24 ; 11
be: 10 92 01 01 sts 0x0101, r1 ; 0x800101 <_edata+0x1>
c2: 10 92 00 01 sts 0x0100, r1 ; 0x800100 <_edata>
c6: 9f 91 pop r25
c8: 8f 91 pop r24
ca: 2f 91 pop r18
cc: 1f 90 pop r1
ce: 1f be out 0x3f, r1 ; 63
d0: 1f 90 pop r1
d2: 18 95 reti
000000d4 <__vector_default>:
d4: 40 9a sbi 0x08, 0 ; 8
d6: ff cf rjmp .-2 ; 0xd6 <__vector_default+0x2>
000000d8 <main>:
d8: 55 9a sbi 0x0a, 5 ; 10
da: 38 9a sbi 0x07, 0 ; 7
dc: 5d 9a sbi 0x0b, 5 ; 11
de: 80 91 6e 00 lds r24, 0x006E ; 0x80006e <__TEXT_REGION_LENGTH__+0x7e006e>
e2: 81 60 ori r24, 0x01 ; 1
e4: 80 93 6e 00 sts 0x006E, r24 ; 0x80006e <__TEXT_REGION_LENGTH__+0x7e006e>
e8: 16 bc out 0x26, r1 ; 38
ea: 85 b5 in r24, 0x25 ; 37
ec: 81 60 ori r24, 0x01 ; 1
ee: 85 bd out 0x25, r24 ; 37
f0: 78 94 sei
f2: ff cf rjmp .-2 ; 0xf2 <main+0x1a>
000000f4 <_exit>:
f4: f8 94 cli
000000f6 <__stop_program>:
f6: ff cf rjmp .-2 ; 0xf6 <__stop_program>
Thanks for your help.
Cheers,
Smokehead
