atmega328p irremote sendsony problem
I try to transmit through one Arduino atmega328p) and receive through the second, using the irremote library On a transmiting Arduino, the IR diode is connected to the D3 leg I'm trying to transmit to the receiving Arduino using the IRremote library itself I transmit with this sketch http://paste.org.ru/?fzqypv I receive the signal using this sketch http://paste.org.ru/?9ebqeu
and I take the following every 4sec http://i7.5cm.ru/i/l3Xo.jpg each time some different length of the package Raw(*) from 14 to 26 the time intervals with duration at all not understandable for me. IRremote recognized the sent signal as Unknown encoding.
Help to understand why irsend.sendSony doesn't work?
Please post your programs here after reading Read this before posting a programming question and follow the instructions for posting code
Try commenting out the unused SoftwareSerial in the sender. SoftwareSerial and IRremote both use a timer and I would suspect a conflict.
thank you very much
thank you very much
thank you very much
thank you very much
I fixed it as you said and everything works like clockwork.
You saved me a lot of time in solving this problem.
May God protect you.
smile smile smile for you.
I'm glad that worked.
