Dear all,
could you please offer some explanation to my following question:
If I understand correctly, the reset pin on atmega328p has to be pulled low in order to reset the uC? On Arduino Uno, the atmega16U2 is responsible for resetting the atmega328p in order to upload new sketches right?
What about on power-up (plugging the Arduino to a power source)? The controller also resets? How is this performed?Does it have an internal reset?
I would like to have a standalone atmega328p on another board and program it via the Arduino Uno (using the Arduino bootloader). Once the chip is bootloaded, only Rx,Tx, RESET, VCC and GND are needed to do this.
My main question: If I program the atmega328p chip via Arduino Uno and then remove the Uno and unplug the atmega328p from power, what will happen, when I power the atmega328p back on as a standalone chip? Will it reset and start normally? If not, could you please explain what should I do to achieve this?
Thank you and best regards,
K
