Atmega328P Reset Pin DIrect To Positive Supply
Hi All
Im building a PCB with an Atmega328p running Arduino. The Atmega will be programmed by the distributor and never needs to be reprogrammed. Can I connect the reset pin directly to +5v instead of using a pull up resistor?
Cheers
Yes.
There is also a fuse to disable RESET.
Thanks. Curious if the Atmega can be programmed again after that fuse is set?
Yes. With a High Voltage Programmer.
