ATmega328P, Timer0, PWM, Phase Correct
I’m trying to set up a timer like described on the title but the output is always high (5V all the time).
The code is this:
void setup(){
DDRD = (1 << DDD6) | (1 << DDD5);
TCCR0A = 1 << COM0A1 | 0 << COM0A0 | 1 << COM0B1 | 0 << COM0B0 | 0 << WGM01 | 1 << WGM00;
TCCR0B = 1 << WGM02 | 1 << CS02 | 0 << CS01 | 0 << CS00;
OCR0A = 44; //neutral
OCR0B = 44; //neutral
void loop(){
It will be a error on the code or it’s some bug of the chip?
Best regards
From a first impression, the definitions look correct. Perhaps you should try this not in the Arduino setup/loop structure, but as a simple main?
void main() {
  // same register definitions
  while (1);
That will probably require #include <avr/io.h>, maybe some other libraries?
Edit: Just to be on the safe side, you measured the signal with a scope / fast logic analyzer, right?
Ze_L:
It will be an error in the code.
Without checking your other stuff, exactly how long do you expect the duty cycle to be?
thanks all for the comments.
about de duty cycle to the neutral position, i think that 44 is correct because i want aprox 1400 us
It looks like you are using mode 7, fast PWM with top at OCR0A.
Since your top is 44, and your duty cycle is 44, it will be always on.
I think it’s Phase Correct PWM (mode 5) - note the 0 for WGM01…
Oops, yes you are right. That's why I don't like it when people mention bits that are not used. :)
Mode 5 still tops at OCR0A.
[quote author=Nick Gammon link=msg=2128880 date=1425759515] Oops, yes you are right. That's why I don't like it when people mention bits that are not used. :) [/quote]
True, it confused me quite a bit too until I got it sorted out... I think... :-) Definitely not recommended for code readability!
[quote author=Nick Gammon link=msg=2128880 date=1425759515] Mode 5 still tops at OCR0A. [/quote]
Yes. I do wish the OP would give us some more details. Maybe I'll find the time today to actually run this code on some Arduino and see what I get.
Looks like I was right. If I change the code to this:
void setup(){
  OCR0A = 44;
  OCR0B = 22;
void loop() { }
I measure 714 Hz (period 1400 µS) with a duty cycle of 50%, on pin D5.
[quote author=Nick Gammon link=msg=2129150 date=1425771332] Looks like I was right. If I change the code to this: [/quote]
Ah, you beat me to it :)
I just finished my own check, and you were right Nick. In Phase Correct PWM with Compare Output mode, as in our case, the pin sets and clears when the counter TCNT0 matches OCR0x on the way up and on the way down. Now, in mode 5, TCNT0 only goes up to OCR0A, so the pin never clears (or, in inverted mode, never sets).
Your corrected code works for the OC0B pin (PD5) because its target (22) is lower than OCR0A (44). If the OP wishes to get a PWM on two separate pins, it will require working in mode 1 (where TCNT0 goes all the way to 255), or setting pins "manually" in interrupt functions.
Well, that was a nice exercise in figuring out the datasheet :)
Always fun to do. And to make sense of all those timer modes. :)
Thanks all for the answers. Sorry about my time to response, i was out for a days.
Yes, i want to work with 2 outputs. My first code was with timer1 and worked well. I was trying to do it with timer0 or 2 because i had a limitation at the hardware.
I have just solved my problem with the hardware. Now, i can use it (timer1).
One more time, thanks all for the answers.
At the end of the year maybe i can show you my project. Best regards
