ATMEGA328P UNO BOARD evaluation
I am evaluating ATMEGA328P UNO BOARD for multi sensor applications from hardware ans software perspective.
I got four sensor , shaft encoder, Zigbee and driver circuitry ( chip) to control a DC motor.
Pin out Budget:
  1. Sensor1 ( ADC0, )
  2. Sensor2 (ADC1,)
  3. Sensor3 ( ADC2,)
  4. Shaft Encoder sensor ( ADC3, ADC4,)
  5. Motor output to control the motor driver chip ( PB0, PB1, PB2, PB3)
  6. Zigbee ( UART, PD0 TxD, PD1 RxD)
My questions are as follows
  1. Can ATMEGA328P allow individual pins of its ADC to be sampled? I want to do interrupt checking for the each individual pins. or does it read the 6 bit number at the same time.
  2. Will the ATMEGA328P be able to pull off this much work load?
  3. What libraries are available for the Zigbee? I want to build the mesh network for 500 units. What would be the best Zigbee kit to go with and please some advise on building such a network.
erica
Analog inputs are read one at a time using analogRead(Ax), x = analog input pin 0 to 5 on Uno.
  1. Will the ATMEGA328P be able to pull off this much work load?
Almost certainly. Without knowing more about the setup can't say for sure.
Note that pins 0 and 1 (RX and TX) are used to program the 328 through the IDE so you might need to consider using a software serial for the BT.
Yes.
Why?
  1. Shaft Encoder sensor ( ADC3, ADC4,)
Why is an apparently digital device connected to, apparently, analog pins?
While still doing nothing 99% of the time.
  1. What libraries are available for the Zigbee?
Andrew Rapp wrote the one everybody uses, if they need a library at all.
Nothing like starting off small. What are the XBees going to be doing?
For what definition of best?
Go big or go home.
PaulS:
I agree the Zigbee device may not need a special library. The Zigbee devices I used where treated as normal serial devices.
XBee makes some Zigbee devices but not all Zigbee devices are XBees.
