Hello,
I'm trying to upload a bootloader to my atmega328p on a custom pcb containing external oscillator at 16MHz. It is possible to upload program via ICSP pins using Arduino as ISP (Official Arduino Uno) but not possible to upload a bootloader. This pcb needs bootloader as it will be used via FT232RL interface.
I've tried to upload bootloader at 115200 baud rate but that did not read any device signature. Also exact definition of my IC is "ATMEGA328P-AU TQFP-32 8-bit 20MHz", if it helps.
P.S That exact definition says it is 20MHz but I suspect that's correct as I don't entirely trust that shop.
Thanks in advance
Upload log
Sketch uses 1626 bytes (5%) of program storage space. Maximum is 32256 bytes.
Global variables use 192 bytes (9%) of dynamic memory, leaving 1856 bytes for local variables. Maximum is 2048 bytes.
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbmodem14101 -b115200 -D -Uflash:w:/var/folders/9z/8cpdsm0518x0b85yx7n4y_0c0000gn/T/arduino_build_452635/sketch_dec06a.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/deniz/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem14101
Using Programmer : arduino
Overriding Baud Rate : 115200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "/var/folders/9z/8cpdsm0518x0b85yx7n4y_0c0000gn/T/arduino_build_452635/sketch_dec06a.ino.hex"
avrdude: writing flash (1626 bytes):
Writing | ################################################## | 100% 0.27s
avrdude: 1626 bytes of flash written
avrdude: verifying flash memory against /var/folders/9z/8cpdsm0518x0b85yx7n4y_0c0000gn/T/arduino_build_452635/sketch_dec06a.ino.hex:
avrdude: load data flash data from input file /var/folders/9z/8cpdsm0518x0b85yx7n4y_0c0000gn/T/arduino_build_452635/sketch_dec06a.ino.hex:
avrdude: input file /var/folders/9z/8cpdsm0518x0b85yx7n4y_0c0000gn/T/arduino_build_452635/sketch_dec06a.ino.hex contains 1626 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.21s
avrdude: verifying ...
avrdude: 1626 bytes of flash verified
avrdude done. Thank you.
Bootloader log (P.S. all sync attempts happen at the same time)
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -P/dev/cu.usbmodem14101 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
Using Programmer : stk500v1
Overriding Baud Rate : 19200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x60
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x66
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x78
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x1e
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x06
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x7e
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xe6
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x80
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x98
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x80
