Hiya!
So my goal is to have a transceiver send out data to a receiver so that when it is received, the receiver will tell it's atmega328P to send out a HIGH to certain pins its connected to, e.g speaker and led will go off that's connected
the transmitter will also be connected to a atmega328P which will be reading a voltage from a ultrasonic sensor reading distance (code i have), e.g when certain distance is detected it will send a voltage to the chip and if its a certain voltage the atmega328P will tell the transmitter to send out data to the receiver letting it know time to trigger those LED, speaker
hope that cleared up what i am trying to do
my main focus is figuring out the communication part of these transceivers, for this application. i have the rest of the code ready and plan to just fill in the blanks once i can get this transceiver code to work
to keep things simple, just having the transciever send data to let the reciever know to have its atmega328P output a HIGH on one of the pins
this is the code i have so far, would you please assist me, thank you
code for transmitter
//RECIEVER
#include <SPI.h>
#include "RF24.h" // libary for transreciever
RF24 myRadio (7, 8);
#include <SPI.h>
#include "RF24.h"byte addresses[][6] = {"0"}; //this is the "pipe" to communicate with each other
struct package // data
typedef struct package Package;
Package data;
myRadio.begin();
myRadio.setChannel(115); // up to 126 channels, pick one to communicate
myRadio.setPALevel(RF24_PA_MAX); //maximum transmitting power = more range
myRadio.setDataRate( RF24_250KBPS ) ; // lowest data rate, more range
myRadio.openWritingPipe( addresses[0]);
myRadio.write(&data, sizeof(data));
Serial.print("\nPackage:");
Serial.print(data.id);
Serial.print("\n");
code for receiver
#include <SPI.h>
#include "RF24.h"
struct package
Package data;
myRadio.begin();
myRadio.openReadingPipe(1, addresses[0]);
myRadio.startListening();
if ( myRadio.available())
while (myRadio.available())
myRadio.read( &data, sizeof(data) );
