Hi All
I am new to this world trying to learn my best :o
I got this board
https://robotdyn.com/uno-wifi-r3-atmega328p-esp8266-32mb-flash-usb-ttl-ch340g-micro-usb.html
I compiled code for UNO to monitor Temp sensor ( DIP SWITCH 3,4 ON )Rest off with below code :
// OneWire(Edison) for i686 - Version: Latest
#include <OneWire.h>
// DallasTemperature(Edison) for i686 - Version: Latest
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 8
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
float Celsius = 0;
float Fahrenheit = 0;
sensors.begin();
pinMode(13, OUTPUT);
sensors.requestTemperatures();
Celsius = sensors.getTempCByIndex(0);
Fahrenheit = sensors.toFahrenheit(Celsius);
Serial.print(Celsius);
Serial.print(" C ");
Serial.print(Fahrenheit);
Serial.println(" F");
digitalWrite(13, HIGH);
digitalWrite(13, LOW);
delay(5000);
the terminal shows data from the UNO board (attached image )(UNO sensor.PNG)
and I configured this in IOT cloud beta for ESP8266.
and complied the ESP8266 with DIP switch (5,6,7 on ) rest off
Sketch generated by the Arduino IoT Cloud Thing "temp"
https://create.arduino.cc/cloud/things/98e07e0b-9e0c-488f-b193-df704e5541b9
Arduino IoT Cloud Properties description
The following variables are automatically generated and updated when changes are made to the Thing properties
CloudTemperature sensorRoom;
CloudTemperature srial;
float ardunin;
Properties which are marked as READ/WRITE in the Cloud Thing will also have functions
which are called when their values are changed from the Dashboard.
These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
// Initialize serial and wait for port to open:
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
delay(1500);
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
The following function allows you to obtain more information
related to the state of network and IoT Cloud connection and errors
the higher number the more granular information you’ll get.
The default is 0 (only errors).
Maximum is 4
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
ArduinoCloud.update();
// Your code here
Serial.print("Temperature = ");
Serial.print(sensorRoom);
Serial.println(" °C");
void onArduninChange() {
// Do something
when connecting to ESP8266 with dip switych 5,6,7 on rest Off
I see the terminal showing 0 only not actual readings from UNO attched image (ESPmonitr.PNG)
Dashboard in IOT showing the 0 value not the actual value of UNO (Attached image )(dashboard)
I want to make the dashboard shows what in UNO
Please help me
