I'm using a bare ATMega328P to do a lot of high-speed serial communication and I think I want to use a 14.7456 MHz crystal to better match the clock to baud rates and reduce errors over time. I'm programming the chip with a USBTinyISP programmer from the Arduino IDE. I'm not using a bootloader.
What steps (if any) do I have to take to ensure that the serial hardware in the ATMega328P gets set up correctly to account for the 14.7456 Mhz clock? I found this old thread SOLVED! ATMega328P at 14.7456 MHz - Other Hardware Development - Arduino Forum which seems to discuss the same goal but some critical messages in the thread relating to the solution appear to be missing now. I understand from what I read in that thread that delay() and friends won't be accurate at 14.7456 Mhz but I could live with that if my baud rates are correct.
Has anyone done this and can describe the software steps to take?
When not using bootloader, you have to change the crystal frequency in board.txt for your particular board, ie:
you can modify wiring.c and implement a delayMicroseconds() for 14.7456MHz...
i wrote one for 1Mhz clock:
#else
// for the 1MHz clock
// for a 8-microsecond delay, simply return. the overhead of the
// the function calls takes more than 8 microseconds. can't just
// substract eight, since us is unsigned; we'd overflow.
if (--us == 0)
return;
if (--us == 0)
return;
if (--us == 0)
return;
if (--us == 0)
return;
if (--us == 0)
return;
if (--us == 0)
return;
if (--us == 0)
return;
if (--us == 0)
return;
// the following loop takes two microsecond (4 cycles)
// per iteration, so execute it once for each two microsecond
// of delay requested
us >>= 1;
#endif
SaintGimp:
None.
In theory....
You'll need to add a new entry to "boards.txt" to tell the Arduino libraries your clock speed. After that the "Serial.begin()" function will do the math for you.
